Author Topic: Fusion 360 under Linux  (Read 652 times)
Offline Mick
« on: May 01, 2019, 03:49:53 am »
Hi everyone, Not sure if this is interesting to anyone but I'll document my outcome here for anyone wanting to install Autodesk Fusion 360 under xUbuntu 18.04 and maybe other distros of Linux.
Prerequisite
curl https://dl.winehq.org/wine-builds/winehq.key -O
sudo apt-key add winehq.key
sudo apt-add-repository 'deb https://dl.winehq.org/wine-builds/ubuntu/ bionic main'
sudo apt install --install-recommends winehq-stable
sudo apt install --install-recommends winetricks
winetricks atmlib gdiplus msxml3 msxml6 vcrun2017 ie8 corefonts fontsmooth=rgb winhttp win7
winetricks d3d11=disabled
Installation
curl dl.appstreaming.autodesk.com/production/installers/Fusion%20360%20Admin%20Install.exe -O
7z x -osetup/ "Fusion%20360%20Admin%20Install.exe"
curl -Lo setup/platform.py github.com/python/cpython/raw/3.5/Lib/platform.py
sed -i 's/winver._platform_version or //' setup/platform.py
wine setup/streamer.exe -p deploy -g -f log.txt
Once up and running select DirectX 9 for graphics driver in Fusion preferences and then re-enable d3d11 (DirectX 11) in winetricks.
Updates
Same as installation but flag an update in step 5.
wine setup/streamer.exe -p update -g -f log.txt
Enjoy, Mick
Ref: https://gist.github.com/probonopd/0fab254aa0b6fc371d8db641822bd530#gistcomment-2799597
The following users thanked this post: jancumps, langwadt, dcarr, aandrew, Technobabble_
Offline Bicurico
  • Country: pt
    • VMA's Satellite Blog
Re: Fusion 360 under Linux
« Reply #1 on: May 01, 2019, 09:23:25 am »
Cool!
Offline Mick
« Reply #2 on: May 23, 2019, 12:05:24 pm »
Quick footnote, Have also installed Fusion on Debian stretch-current (9.9)
Had to install using win10 compatibility layer then switch to win7, otherwise wrong library's get installed!!!  :palm:
winetrick win10
winetricks win7
« Last Edit: May 24, 2019, 10:41:10 am by Mick »
