Damn, I must have missed a notification! Sorry, didn't see the replies.
I know packed columns have great limitations over modern ones, but the big advantage i want to exploit is the significantly lower required carrier gas pressure, and greater column capacity.
So, I made a packed column myself, 40cm, just packed with alumina. It probably won't give much (any) analytically significant separation, but it will do the trick of restricting the flow through the system.
I finished my room temperature prototype, whether it does anything sciency is TBD, but atleast it looks fairly proffessional.
What is shown is the entire setup: the swage-lok tee has a septum under the third nut, and the straight tubing holds a diode sinking current and heating itself, used as a crude unbalanced TCD.
I have seen packed columns on ebay for reasonable prices but I've always had reservations about possible unknown nasty residues in them, but I guess I could look out for NOS ones too.
I don't have any specific applications in mind, I just think there might be an interest in an idiot proof, higher capacity instrument to analyze undiluted samples from reaction mixtures and such.
Thanks for your replies and sorry for the previous lack of mine.
