Author Topic: Generate PCB ASCII file using AI  (Read 790 times)
Offline CirclotronTopic starter
« on: November 14, 2023, 02:46:25 am »
So there is text based AI and image based AI. Maybe that's an oversimplification but you know what I mean. Anyway, I wonder of the day will come where you can feed in a written instruction of the details of the PCB you want drawn, and instead of producing an image it comes up with an ASCII text file for the PCB in your chosen format. Then you open it with your favourite PCB editor to check it out and away you go. That would be pretty cool.
Online SiliconWizard
Re: Generate PCB ASCII file using AI
« Reply #1 on: November 14, 2023, 04:41:38 am »
The clock is ticking
Placement of the "L" letter in this sentence is key.
Offline Someone
    • send complaints here
« Reply #2 on: November 15, 2023, 01:26:46 am »
Already there:
https://doi.org/10.48550/arXiv.2303.12712
"draw a unicorn"
