Fast breeders are known for decades now, and in some let's just say more nuclear-advanced countries are already used commercially. They can operate on a nuclear waste as a fuel, killing two birds with one stone - using up piles of nuclear waste accumulated all over the world, and creating essentially free energy at the same time! Due to all that nuclear hysteria Germany has falled far behind in the nuclear tech. But the future of humanity is in nuclear energy, whether some people like it or not, as no other power source can provide enough energy for our ever-expanding needs.
Frankly, I agree with the stance that the actually existing nuclear power plants are pressurized water reactor or scrubber reactor, so they have inherent security risks in case of danger.
This is partly due to the military in the cold war, that wanted reactor types that could provide them with material for bombs. Other types of reactor (Thorium types) are probably way less dangerous in case of an accident.
BEven if they would now want to extend the life-time for the few remaining German reactors, it would now take quite some time for a major revision and maininance and also to get new fuel. So they would be down for 1-2 years anyway. In hind-sight it may have been better to keep the reactors running for longer, but that decision point was some 5-10 years ago. All plans are made to shut them down. Already the last extension was only with reduced power, as the fuel was essentially used up.
1) When not running the reactors 24/7, but shut down in times of low demand, the already high costs additionally go up. A limited power (like 25%) to run near 24/7 is not such an issue, but this still leaves a large part to come from other source.
2) Having many reactors of the same / similar type is a risky situation. The safety concepts usually call a prompt shut down if a problem with the design is found (e.g. like with the BWRs in Fukushima). Taking safety serious may than cause a black out. So one has to choose between safe or dependable. Given the hard choices and reaction after Fukushima (delaying safety upgrades to keep the reacrtor running) one can not really trust the promissed safety.
3) For a world wide large scale expansion of nuclear power the uranium reserves get critical and the fuel would get more expensive. It would at least need reprocessing of used fuel and this did not work out economically.
3) For a world wide large scale expansion of nuclear power the uranium reserves get critical and the fuel would get more expensive. It would at least need reprocessing of used fuel and this did not work out economically.I'm not an economist but from what I know the percentage of the fuel cost is a low one digit figure of the total operational cost of a NPP. So this is not really a factor, and also the reason why reprocessing and breeder reactors were not economically interesting to this date.
Something I have always wondered about but not looked into is since the spent fuel is still active enough that it has to be kept cool, clearly there is still potential energy there so why can't it be put to use?
Building new nuclear power plants makes relatively limited sense.
This. It's worth noting the Finnish Olkiluoto 3, which now seems kinda-sorta operational (!!!), after being 12 years late, is now the most expensive building in the whole human history; a total political disaster.
Nuclear reactors are finicky/metastable
Nuclear reactors are finicky/metastableHuh? Commercial reactors are designed to be undermoderated, i.e., an increase in fuel temperature or a reduction in moderator density leads to a power reduction. For this reason, in a PWR, slight variations in power demand up to a few percent do not require any input from power control elements. In fact, I can assure you from first hand experience that you can safely turn off all closed loop reactor power control (actually three control loops in series in a German PWR in normal at-power operation), and it will just sit there without moving (stable equilibrium).
Something I have always wondered about but not looked into is since the spent fuel is still active enough that it has to be kept cool, clearly there is still potential energy there so why can't it be put to use?After a four or five years when the spent fuel assemblies are transferred to dry storage, this is just a couple of kilowatts, i.e., not worthwhile. For example, this storage cask is rated for a maximum of 39 kW total heat load.
Something I have always wondered about but not looked into is since the spent fuel is still active enough that it has to be kept cool, clearly there is still potential energy there so why can't it be put to use?Nuclear reactors are finicky/metastable and only use a small percentage of the "available" energy in the fuel. It gets into the specifics of the particular fuel cycles
[Sounds like an example of short term stability, not a truly stable system hence the careful choice of metastability as a description. Leaving an inherently safe/stable reactor to its own devices usually means a rapid and steady drop in reactivity (for legitimate and well thought out safety reasons) rather than continued stable operation. They are intentionally not stable, and partly because of the fuel becoming unable to sustain fission (despite having not yet used much of the available energy).
Someone asks about energy, so subtly direct the discussion to power....
The answer is complex and multifaceted, but it is true that very very little of the available nuclear energy is used in current fuel cycles.
Actually, I had decided not to discuss this topic anymore. Having worked in the nuclear sector in Germany, I know the industry and the German plants quite well. The amount of irrationality in this discussion is only making my stomach churn and I've had enough gray hairs from this. What you get to hear even from people with an engineering background is not always easy to take.
What makes all this particularly deplorable is that the German DWR 1300 and Konvoi plants designed by KWU were far ahead of its time, especially in terms of engineered safety features and I&C (instrumentation and control), and only current designs like the EPR draw level in this aspect (you've got to know that 25 yeas is a short period in this industry). Operational experience is excellent. A whole bunch of disturbances and difficulties the industry constantly deals with with abroad has been avoided through good design and also a fortunate choice of materials (the other day I've heard that they run "leak management programs" in the US ...). The plants have excellent controllability for a large-scale (1450 MW gross) power plant, and can do power gradients up to 150 MW/min from zero to full load (although some restrictions may apply in some operational regimes), all at the push of a single button. They were always designed to do load-following operation, and also did that on a regular basis.
But let them turn off this crap. It seems that this technology is too sophisticated for the country's soul. I'm done with this. Sorry for getting emotional over this.
Germany is turning the nuclear power plants off and France is building new nuclear plants and gets EU funding for them because of clean energy.
What do you think, would it be possible to run these plants with the existing (loaded in) fuel rods for a few more months or years even with reduced capacity?
What would it require?
And how much outage would mean the refuelling? If the aim is to make it work for another 1-2 years? Would the costs, risk or time to do it enormus?
Besides I really can't understand, why this few GW needs to be subsituted so immediately with coal, it is about 5% of Germany's need so not so systemrelevant.
But I mean with the needed maintenance for the few years extra running time. Because for me it is not clear wheter this is a pure political decision, and you only had to change the fuel, or it is such an enormous cost or time issue which makes it uncompetitive with other solutions.
Power systems are like that. If you have more consumption than production, the whole grid collapses, so you can't just cut 5%, or even 0.5% of production, you need to replace it with something else; or make customers somehow cut down their consumption. Germany has a lot of heavy industry which can't be turned off. 5% sounds like a small number but it's the difference between life and death (for the industries).
These plants are designed to operate safely for much more than half a century. It's not that extending the operational life by "a few years" is any problem. It's extension after extension after extension after extension which gradually becomes a problem. AFAIK, this practice is being critiqued in the USA.
And what if that decision had been made immediately after the government got the results of the studies regarding the possible enlenghtening of the usage of the plants?
If there would be a political will, could it be made economically feasible in a timeframe and for costs that would beat power to gas initiatives (or maybe renewables)during the same time period?
