That was what I thought too and I cut the lead at the end and then cut a a quarter inch of the probe body at the tail, and resoldered the lead wire, but that did not help. The failure was somewhere inside the probe. It is a known issue with Fluke TL175 probes. So I went ahead today and cut into the probe first closer to the tip but hit shiny metal, so did another cut in the middle of the probe and found the junction by trial and error. As shown in the attached pictures, the lead wire is crimped to the tip and apparently the crimp quality was poor. When you pull or push the lead wire at the tail you get unstable probe resistance between 12 and 0.3 Ohm. I used a blunt nail and a couple hits with a hummer to re-crimp the joint and probe resistance measured close to zero Ohm, so the connection was restored. I still went ahead and soldered a short jumper between the tip tubing and the lead wire as shown in the photo.
Now to repair the body, I think I will get a JB Plastic Weld and fill the opening, then sand it to the shape.
