Author Topic: Glue - safest to use on PCBs?  (Read 1085 times)
Offline SolderSuckerTopic starter
« on: August 10, 2020, 01:46:14 pm »
I need to stick some small anti-static foam sheets to the solder side of some PCBs - what is the best type of glue to use for this?
I was thinking of something live Evo-Stick impact adhesive, it's of course highly flammable when in liquid form but I believe it's inert when set. Or is there a better alternative?
Offline tooki
Re: Glue - safest to use on PCBs?
« Reply #1 on: August 10, 2020, 03:12:19 pm »
Antistatic (pink) or static dissipative (black) foam? For the pink stuff I’d just use double stick tape. For the black one, I’m not sure.
Offline Mr. Scram
  • Display aficionado
« Reply #2 on: August 10, 2020, 03:24:00 pm »
Be careful not to introduce another source of static.
« Reply #3 on: August 10, 2020, 03:32:43 pm »
No, not bubble wrap or similar, in this particular case this is some dense black antistatic foam material which is backed by some type of cardboard or plastic - it was originally stuck in place with some kind of glue and I needed to peel it off to get at the solder side of the board, now of course it's lost some of its adhesive qualities and won't stay stuck down any more (and I do need to stick it back in place).
Offline tooki
« Reply #4 on: August 10, 2020, 04:07:13 pm »
Don’t put words in my mouth: I didn’t say anything about bubble wrap. There’s pink antistatic foam (several types, actually) and black static dissipative foam.
Anyway, if it’s got a rigid backing, just use fresh double stick tape.
Online tom66
« Reply #5 on: August 10, 2020, 05:44:27 pm »
Be careful.  I used to repair power supplies in Samsung and LG televisions and it was very common for the glue they used to become conductive over time and short circuit things on the power supply board.  A favourite was gunk across the Class-Y capacitor which could bring the low-voltage outputs on the TV up to near mains potential (2-pin supply only, no PE, so aerial socket could become live.)
The following users thanked this post: SolderSucker
« Reply #6 on: August 10, 2020, 06:11:44 pm »
Thanks, that's useful to know. In this case it's only being used on a 5VDC board, nevertheless I still don't want any shorts to occur due to the glue becoming conductive.
« Reply #7 on: August 10, 2020, 06:17:59 pm »
Gel type superglue is about the best, though you will have a white bloom on the board when you eventually remove it again, but it is at least not conductive.
Offline maginnovision
« Reply #8 on: August 11, 2020, 12:58:57 am »
Go2glue works as well, dries clear but is very conductive for a while as it dries. I've also used conformal coats as board adhesives but it can take a really long time to dry if you're not careful.
Online NiHaoMike
    • Facebook Page
« Reply #9 on: August 11, 2020, 01:26:59 am »
There's a special silicone specifically designed for use on electronics. Super glue and hot glue are also good choices.
Offline coppercone2
« Reply #10 on: August 11, 2020, 06:50:21 am »
I like this one too, but keep in mind it contains benzeneish things. Excellent adhesive however. Not sure how benzene vapors effect electronics plastics either. I use it sparingly as strain relief.
https://echa.europa.eu/substance-information/-/substanceinfo/100.060.937
from a health stand point, it seems to stand up to its 'nice' smell. One of the only adhesives I like the smell of actually. Acrylic epoxies smell kind of ok (minty). Go2Glue is like menthol or something.
Not a skin or eye irritant; No evidence of skin sensitization in humans or guinea pigs; No evidence of reproductive or developmental toxicity; [ToxPlanet: EC: SCTEE] Not expected to cause adverse health effects; [Solutia MSDS] See "Dodecylbenzene."
« Last Edit: August 11, 2020, 06:58:31 am by coppercone2 »
