Author Topic: 121GW Multimeter: Odd LCD Behaviour  (Read 2179 times)
Offline HalcyonTopic starter
  • Global Moderator
« on: January 10, 2018, 02:03:55 am »
I noticed something strange, when I swiped my hand over the LCD, random segments would light up momentarily, even though the unit was switched off. It persisted like this for several hours. Static build-up making it through the clear plastic casing onto the LCD segments?
Offline wraper
  • Country: lv
Re: 121GW Multimeter: Odd LCD Behaviour
« Reply #1 on: January 10, 2018, 02:10:59 am »
Apparently, I think I've seen this on some devices.
I assume it does not happen if switched on.
Offline lowimpedance
  • Watts in an ohm?
« Reply #2 on: January 10, 2018, 02:18:00 am »
Just tried with mine, which still has the screen protector on, and no segments showed. As for yours do these 'illuminated' segments disappear immediately you turn the meter on ?.
Anyway it would be static build up in the plastic screen. I have seen this behaviour as well with bare LCD screens.
Offline gnavigator1007
« Reply #3 on: January 10, 2018, 02:18:41 am »
I noticed this peeling off the screen protector. Didn't persist long, but I could do it over and over again.
Offline Muttley Snickers
  • Cursed: 679 times
« Reply #4 on: January 10, 2018, 02:19:03 am »
So that we don't end up with a multitude of similar threads you might want to post this issue in the dedicated 121GW thread located in the Test Equipment section.
https://www.eevblog.com/forum/testgear/eevblog-121gw-multimeter-issues/
Offline tablatronix
« Reply #5 on: January 10, 2018, 02:30:57 am »
I see this all the time, very normal, some kind if static charge. Always goes away.
I install devices with lcd and plastic protectors alot.
  • Global Moderator
« Reply #6 on: January 10, 2018, 03:26:00 am »
Thanks guys, yes, it started immediately after peeling off the plastic protector. The effect only lasted for a few hours until it appears the charge dissipated. I wouldn't exactly call it an "issue", just a temporary quirk. The first time I thought I just imagined it.
Offline Ampera
    • Ampera's Forums
« Reply #7 on: January 10, 2018, 04:04:02 am »
You're gonna have to tell me how good it is so I can get jealous enough to maybe buy one when they go public.
I forget who I am sometimes, but then I remember that it's probably not worth remembering.
EEVBlog IRC Admin - Join us on irc.austnet.org #eevblog
Offline Ampera
    • Ampera's Forums
« Reply #8 on: January 10, 2018, 05:36:38 am »
Sadly I have occasional use for a multimeter, but I expect that to change in the coming years, so perhaps a bit of an investment to help a creator I love so much would be worth it for me.
I also am like Dave and can't resist touching buttons and twiddling knobs, and multimeters tend to have the best knobs and buttons available.
Offline nidlaX
« Reply #9 on: January 10, 2018, 08:40:51 am »
Didn't Dave demonstrate this effect in his recent LCD design video?
Offline xygor
« Reply #10 on: January 10, 2018, 10:27:20 am »
Drop its temperature to -40.  Then what does it display?
