Say you are on a non-rotating earth size planet with no atmosphere and no other objects with gravity exist. Totally alone in the universe. You fling a projectile away from the planet in a straight line and the faster you fling it the further it will go before it eventually falls back to the ground. Because the gravity from this planet gets asymptotically weaker the further you get from the planet, but (presumably) never actually ceases, would it be possible to fling your projectile fast enough so that it would never fall back to the ground? Or would gravity, no matter how weak, eventually win and make it come back?
