Quote soldar said the strips in the plugs, not the receptacles, get dirty. So covered receptacles won’t help the situation described. covers wont,but the design of ceeforms make it less likely for the plugs to get as bunged up with dirt
Quote from: nctnico on May 31, 2024, 01:13:51 pmQuote from: soldar on May 31, 2024, 01:09:37 pmI was just talking to a guy who works with electric tools outdoors and in very dusty construction sites and he was telling me he doesn't like how the metal strips in the Schuko plugs get covered and clogged with dust, dirt, etc. and need to be cleaned out.Sounds more like they should be using outlets with a cover (or fix the covers).Quote from: Kjelt on May 31, 2024, 08:26:40 pmQuote from: soldar on May 31, 2024, 01:09:37 pmI was just talking to a guy who works with electric tools outdoors and in very dusty construction sites and he was telling me he doesn't like how the metal strips in the Schuko plugs get covered and clogged with dust, dirt, etc. and need to be cleaned out.He needs the blue industrial quality extension cord style Schukos like picture below.Or even better switch to the IEC 60309 blue 2p+e 16A version:https://en.wikipedia.org/wiki/IEC_60309Guys, guys… soldar said the strips in the plugs, not the receptacles, get dirty. So covered receptacles won’t help the situation described.
Quote from: tooki on June 01, 2024, 12:05:50 pmQuote from: nctnico on May 31, 2024, 01:13:51 pmQuote from: soldar on May 31, 2024, 01:09:37 pmI was just talking to a guy who works with electric tools outdoors and in very dusty construction sites and he was telling me he doesn't like how the metal strips in the Schuko plugs get covered and clogged with dust, dirt, etc. and need to be cleaned out.Sounds more like they should be using outlets with a cover (or fix the covers).Quote from: Kjelt on May 31, 2024, 08:26:40 pmQuote from: soldar on May 31, 2024, 01:09:37 pmI was just talking to a guy who works with electric tools outdoors and in very dusty construction sites and he was telling me he doesn't like how the metal strips in the Schuko plugs get covered and clogged with dust, dirt, etc. and need to be cleaned out.He needs the blue industrial quality extension cord style Schukos like picture below.Or even better switch to the IEC 60309 blue 2p+e 16A version:https://en.wikipedia.org/wiki/IEC_60309Guys, guys… soldar said the strips in the plugs, not the receptacles, get dirty. So covered receptacles won’t help the situation described.Well, dirt is a whole lot easier to remove from exposed strips compared to getting dirt out of a hole. So either way the 'French' schuko is not an improvement in this case.
