Author Topic: Half a kindom for source of these binding posts!  (Read 7641 times)
Offline WartexTopic starter
    • http://headsplosive.com
« on: July 07, 2012, 12:31:50 am »
Hi everyone, I looked and looked and can't find a source of those binding posts. Is there a diff name for them? Many brands of power supplies and programmable loads have them. If you could tell me a source where I can buy them, I will send you some love via Paypal or ship you some components as a reward.
Offline Psi
Re: Half a kindom for source of these binding posts!
« Reply #1 on: July 07, 2012, 01:34:17 am »
The white cap looks custom
Offline Short Circuit
    • White Bream electronics R&D
« Reply #2 on: July 07, 2012, 01:40:21 am »
No id. Easiest way is probably to crop the picture to the terminals and put a buy request on Alibaba (with an appropriate desription to aid the search&match engines). Done that before for other parts succesfully.
Offline Psi
« Reply #3 on: July 07, 2012, 04:27:01 am »
Then you'll get someone respond that they can get them for $1K a set .
(Where they buy the powersupply above and unsolder them :P )
Offline T4P
  • Country: sg
    • T4P
« Reply #4 on: July 07, 2012, 05:27:37 am »
That's a DC load  :P
Offline Psi
« Reply #5 on: July 07, 2012, 07:09:19 am »
That's a DC load  :P
ah, so it is :)
Offline amyk
« Reply #6 on: July 07, 2012, 12:14:33 pm »
The 3711A manual refers to them as "innovative easy to use inputs" or something like that, so it might be a custom part for them. What other products use them?
(Regular binding posts go on Alibaba for as low as $0.001 each. Even with an MOQ of 1000, that's only a $1 order. It's amazing how cheap you can find things like this.)
Offline digsys
    • DIGSYS
« Reply #7 on: July 07, 2012, 12:42:08 pm »
I have a very similar 300W load, which I naturally heavily modified as soon as I received it, as well as just about anything else
I buy from china. On the load and P/Supplies, it is easy enough to find "standard" terminal posts of many types that fit pretty
well. Sometime I make up a custom spacer, or enlarge a hole, but it's worth a little effort. Check wit your favourite suppliers.
Offline olsenn
« Reply #8 on: July 07, 2012, 01:18:26 pm »
I have those same (or at least similar) binding posts on my Itech DC Electronic Load. Unfortunately, however, I have never seen them for sale by themselves.
That being said, check out http://www.futurlec.com/Banana-Posts.shtml  The ones at the bottom of the page look to be quite nice.
« Last Edit: July 07, 2012, 01:20:40 pm by olsenn »
Offline hlavac
  • Country: cz
« Reply #9 on: July 07, 2012, 10:49:33 pm »
Here are some LOL
Good enough is the enemy of the best.
Offline David_AVD
« Reply #10 on: July 07, 2012, 11:02:27 pm »
Altronics sells some nice beefy ones now: http://www.altronics.com.au/index.asp?area=item&id=P9230
Online EEVblog
« Reply #11 on: July 07, 2012, 11:06:38 pm »
[/quote]
My BK precision electronic load uses the same ones.
And AFAIK, Array and BK Precisions parent company are not related. So looks like both have sourced the same terminals.
Dave.
alm
  • Guest
« Reply #12 on: July 07, 2012, 11:49:51 pm »
Any chance BK dummy loads are made by Array?
Online EEVblog
« Reply #13 on: July 08, 2012, 12:10:45 am »
Nope, they are made by their own subsidiary, Itech
http://www.itech.sh/en/products.jsp?id=12&sortid=001005
Dave.
« Reply #14 on: July 08, 2012, 03:19:48 pm »
Anyone?
Offline tramjoe
« Reply #15 on: July 08, 2012, 05:09:50 pm »
I'm curious... what's so great about these ? Can the cap be removed to reveal a banana plug or not even ?
Offline T4P
  • Country: sg
    • T4P
« Reply #16 on: July 08, 2012, 05:52:35 pm »
Binding posts! They are really only good for fork terminals- duh.
« Last Edit: July 08, 2012, 06:59:16 pm by DaveXRT »
« Reply #17 on: July 08, 2012, 06:41:54 pm »
They look good, that's about it.
No cross-hole for bare wire and no 4mm socket for banana's.
Only practical way of terminating is with crimp fork terminals.
Offline dbinokc
« Reply #18 on: July 08, 2012, 07:17:04 pm »
Is it just the knob style of the post you are really interested in? If so, could you have one 3D printed?
Offline amyk
« Reply #19 on: July 09, 2012, 06:45:51 am »
Anyone?
You could go ask Alibaba, or even Array or Itech.
("I would like some spare binding posts for my 3711A..." 8))
Offline dcel
« Reply #20 on: July 09, 2012, 11:45:08 am »
« Last Edit: July 09, 2012, 05:09:40 pm by dcel »
Offline dcel
« Reply #21 on: July 09, 2012, 12:05:53 pm »
I found an 80a version on ebay...
http://www.ebay.com/itm/50x-80A-Power-Amplifier-AC-Power-Binding-Post-M8x58mm-/170664655899
Chris
Wish someone would tell me how to imbed pics into posts.  ::)
Offline Monkeh
« Reply #22 on: July 09, 2012, 01:52:52 pm »
Chris
Like this:
There are big obvious buttons above the text box, too. They even have tooltips.
