Author Topic: Hall effect sensors VS LVDT.  (Read 3580 times)
Offline firewalkerTopic starter
  • Country: gr
« on: December 29, 2017, 10:19:30 am »
A common way in automotive industry to measure absolute position is the use of Hall effect sensors. Like TPS (Throttle Positions Sensor), APP (Accelerator Pedal Position), SAS (Steering Angle Sensor) etc.
When it come to suspension systems the most common sensor is LVDT (Linear Voltage Differential Transformer).
Why? Speed? Sensitivity?
LVDT:
Alexander.
Offline b_force
    • One World Concepts
Re: Hall effect sensors VS LVDT.
« Reply #1 on: December 29, 2017, 01:11:39 pm »
A LVDT is a mechanical way to measure things.
Depending on your application, that could give an extra 'load' on the part that's moving, and therefor you will get different results.
Also mechanical components in general will break or need to be replaced more often.
Besides there are also obvious reasons, like speed, acceleration etc.
That's just matter of checking the specs.
The following users thanked this post: firewalker
Offline HighVoltage
« Reply #2 on: December 29, 2017, 01:40:23 pm »
The newest generation that we find in cars now, are Self Calibrating TPOS Speed Sensors.
They have higher accuracy and faster reaction times.
LVDT is far too slow for most applications.
Since the suspension is relative slow, it is ok to use LVDT
  • Country: gr
« Reply #3 on: December 29, 2017, 01:58:53 pm »
What does True Power On State refers to?
Alexander.
Online David Hess
  • DavidH
« Reply #4 on: December 29, 2017, 03:14:47 pm »
LVDTs are much more reliable than hall effect sensors and especially so under adverse conditions.  Hall effect sensors are just cheap.
Offline HighVoltage
« Reply #5 on: December 29, 2017, 04:30:18 pm »
Alexander.
Here is the datasheet attached.
Features and Benefits:
- Chopper stabilized; optimized for automotive cam sensing applications
- Optimized absolute timing accuracy step size through gradual transition from TPOS to Running Mode
- High immunity to signal anomalies resulting from magnetic overshoot and peak-to-peak field variation
- Tight timing accuracy over full operating temperature range
- True zero-speed operation
- Automatic Gain Control circuitry for air gap independent switchpoints
- Operation at supply voltages down to 3.3 V
- Digital output representing target profile
- Undervoltage lockout (UVLO)
- Patented Hall IC-magnet system
- Increased output fall time for improved radiated emissions performance
  • Country: gr
« Reply #6 on: December 29, 2017, 06:05:20 pm »
So, TPOS means it knows the absolute position of the object immediately after power up. Correct?
Alexander.
Offline HighVoltage
« Reply #7 on: December 29, 2017, 06:29:58 pm »
Yes, and it knows in which direction the shaft is turning.
So, it is one more indication of possible backfire and a reverse running engine, to shut off all fuel supply and ignition.
