Author Topic: Hammerhead shark as electrometer front end  (Read 1460 times)
Offline fcbTopic starter
    • Electron Plus
« on: May 18, 2021, 11:05:29 am »
Does this sound right?  Hammerhead sharks can detect fields of around 1nV/M??
https://youtu.be/lgTbQlfOSKE?t=775
Offline bsfeechannel
Re: Hammerhead shark as electrometer front end
« Reply #1 on: May 19, 2021, 12:15:06 am »
The only way to be sure is to connect a 1.5V battery between Long Island Sound and the waters of Florida and see if it detects it.
The following users thanked this post: fcb
Offline Gyro
« Reply #2 on: May 19, 2021, 10:56:30 am »
Given the number of boats and ships around with sacrificial anodes, I think it would have a hell of a job.
I suspect that its response is low frequency AC rather than DC too. You don't want a hammerhead with uncontrolled drift!
« Last Edit: May 19, 2021, 10:58:55 am by Gyro »
Best Regards, Chris
    • Electron Plus
« Reply #3 on: May 19, 2021, 01:08:56 pm »
Undoubtedly it will be tuned to pulses from muscles in prey, but that's still a hell of a front end, wonder what the bandwidth is, how it filters out noise and if there is a DC blinding effect?
Offline Alex Eisenhut
  • Place text here.
« Reply #4 on: May 19, 2021, 03:47:33 pm »
Don't know about 1nV per meter... but
https://en.wikipedia.org/wiki/Ampullae_of_Lorenzini
"Sharks may be more sensitive to electric fields than any other animal, with a threshold of sensitivity as low as 5 nV/cm"
Offline Gyro
« Reply #5 on: May 19, 2021, 05:53:30 pm »
From the link, it looks as if Hammerheads have Geomagnetic sensing too. Given that they already have inherent biological accelerometers and gyroscopes, the only thing they're missing is GPS!
Best Regards, Chris
« Reply #6 on: May 20, 2021, 02:05:38 am »
I guess they used that comparison in order to demonstrate the orders of magnitude involved to a lay audience. But if you have seen a hammerhead shark hunting, it searches for prey hidden in the sand, maintaining its receptors at a distance of no more than 10cm above the sea bed. These sharks know how to avoid interference.
I think the OP's video got it wrong. They say 1nV/cm², however electric fields are expressed in V/m, not V/m². There's another video which claims that the receptors are capable of sensing 15nV of potential difference, regardless of distance.
« Last Edit: May 20, 2021, 02:15:25 am by bsfeechannel »
Offline cdev
« Reply #7 on: May 20, 2021, 02:10:19 am »
That hammer head sure looks like an antenna or similar to me. this is pretty interesting. I am not a shark or even close. But I can sense small electric currents with my mouth.
« Last Edit: May 20, 2021, 02:17:14 am by cdev »
Offline chickenHeadKnob
« Reply #8 on: May 20, 2021, 05:29:28 am »
This sounds impractical to me, if you try this at work.
Offline Refrigerator
  • Country: lt
« Reply #9 on: May 20, 2021, 07:14:36 pm »
We've all licked a 9V battery.
I have a blog at http://brimmingideas.blogspot.com/ . Now less empty than ever before !
An expert of making MOSFETs explode.
