Hi tristan,
I have a THS720 myself and i think it is perfect.
It has 2 isolated scope channels and a separate DMM also isolated.
The RS 232 is also isolated.
There are free tools available on the web ( screen dump logger FFT ) See the THS Fan site:
http://warped.org/tek/I find myself using it more and more, I also have a fluke 123.
The fluke is a bit more responsive on the key operation and the trend plotting is better than the graphical DMM of the Tek but the tek has many more options like cursor, waveform measurements and trigger options.
The battery can be made by yourself easily, I have build adapters myself to accomodate for 4 AA batteries, 4 Sub-C cells (the ones used in power tools), and also 4 C-type cells can be accommodated.
The C- cells have to be shrink- wrapped because these have only a few mm of room. I think the genuine Tek battery pack is also standard C cell.
The rest can be rolled in cardboard to make the smaller battery pack fit. Battery life is about 1 hour with 1500 mAh cells. (that is the capacity my NiCd capacity meter tells me is in the C-cells) You can buy better cells.
Switch the THS off before changing the battery pack or else your calibration variables are destroyed.
It is easy to calibrate the Tek yourself. You just start the calibration procedure and apply the correct signals.
Maybe something for Dave to checkout?
I like this little scope/dmm even tough it is 15 years old.
