Author Topic: Hands on with the world's thinnest laptop  (Read 7458 times)
Offline MadTux
Re: Hands on with the world's thinnest laptop
« Reply #1 on: November 14, 2016, 03:10:36 am »
That acer POS laptops just last as long as their warranty goes.
Meanwhile I can still beat someone to death with one of my older Thinkpads and probably can still use it afterwards.
Now, as Moores law is slowly declining, it would make sense to build rugged hardware again, because it won't get obsolete in a few years. But instead these idiots make it as flimsy as possible, so it will get destroyed ASAP and the ewaste cycle keeps going  >:(
Offline BradC
« Reply #2 on: November 14, 2016, 05:15:14 am »
I've had the opposite experience with Acer laptops. Both of mine have lasted in excess of 10 years. One was retired due to gutlessness, and the other has just been retired as the backlight is fading a bit and something in the on-board DC-DC converter has started singing. That particular machine has been on 24/7 since 2006. Both of them were on their second HD though.
Offline Ampera
    • Ampera's Forums
« Reply #3 on: November 14, 2016, 05:25:33 am »
There honestly needs to be an easier and better standard for building laptops. There needs to be sockets, standardized form factors, and swapable parts that give the same flexibility as a desktop.
With that I no longer need to get a flimsy case I don't like, I don't have to use piss poor cooling, I can choose the parts exactly for what I need, and I can do it cheaper.
And if a component breaks, I can get away with replacing it instead of just scrapping and tossing the entire laptop.
I forget who I am sometimes, but then I remember that it's probably not worth remembering.
EEVBlog IRC Admin - Join us on irc.austnet.org #eevblog
Offline timgiles
  • Programmer, DB architect
« Reply #4 on: November 14, 2016, 05:41:20 am »
Looks nice, hate all the marketing BS when it gets reviewed. Loose all respect for him when he mentions Acer colour blah blah blah....
IMO laptops last as long as the usage dictates. Sure there are better materials, but in the end if you have a hamfisted numpty that throws it about, does not take care, well it wont last.
Offline meeder
« Reply #5 on: November 14, 2016, 05:42:58 am »
I agree but swappable parts will increase the BOM and "people" want lighter and thinner gear.
I am hauling around a heavy beast as a laptop (Dell XFR E6420) and although very durable it is to thick to be comfortable and the screen resolution is to low for modern software.
Online wraper
  • Country: lv
« Reply #6 on: November 14, 2016, 05:48:02 am »
Project Ara #2, to make bulky and flimsy POS no one buys? Sockets in laptops are standard, you can swap RAM, wifi, HDD, put additional SSD (M.2, mSATA). Want to put powerful GPU? Sorry, but there is not enough space, power supply and cooling in average laptop. Add those things and get a frankenstein sane people won't buy. The only thing which is not standard is motherboard.
« Last Edit: November 14, 2016, 05:50:09 am by wraper »
Offline boffin
« Reply #7 on: November 14, 2016, 06:02:56 am »
My Acer Chromebook is indestructible. Best $129 GroupOn ever.
Offline Rick Law
« Reply #8 on: November 14, 2016, 06:51:47 am »
Reminds me of Sony, latest phone, made of ALKALIDO metal, which is just a proprietary trademark of aluminum.
The first Sony VAIO I used was magnesium alloy - according for the sells flyer, stronger and lighter than aluminum.  I hope this "ALKALIDO metal" is at least some kind of aluminum alloy that has some distinction from run of the mill regular aluminum.  Otherwise, Sony is moving just all more expensive branded version of cheap stuff.
Offline rollatorwieltje
  • I brick your boards.
« Reply #9 on: November 14, 2016, 09:26:00 am »
I own a Macbook Air. I don't see the hype for "thinnest laptop", it causes more problems than it solves. The MBA bends easily, causing the trackpad to jam. I had to bend it back at least twice. My 2010 Macbook Pro with optical slot is already thin enough, and it used a standard laptop harddisk and memory. The display of the MBA is also significantly worse.
Offline AlxDroidDev
  • Country: br
    • Arduino Web Brasil
« Reply #10 on: November 14, 2016, 10:35:52 am »
I'd never buy an Acer.
No matter how thin it is, it's still an Acer.
Actually, I am quite pleased with my 5yo Dell XPS 15.
"The nice thing about standards is that you have so many to choose from." (Andrew S. Tanenbaum)
Offline grifftech
    • youtube channel
« Reply #11 on: November 14, 2016, 09:17:56 pm »
WHAT ABOUT CAPS LOCK
Offline Lightages
  • Canadian po
« Reply #12 on: November 14, 2016, 09:31:23 pm »
Big deal. What does "thinness" have to do with the capabilities of a computer? How about weight, battery life, and computing power? These should almost always be more important than the thickness of the laptop. How thick is too thick? It depends but having the thickness of a notebook as the primary concern is just fashion idiocy.
Offline boffin
« Reply #13 on: November 20, 2016, 09:07:52 pm »
The lack of CAPS LOCK on the Acer Chromebook is a calming influence on all my posts online.  I'm a better person because of it.
Offline NottheDan
« Reply #14 on: November 20, 2016, 10:11:46 pm »
Right above the left shift on the Acer Chromebook 710.
Offline Homer J SimpsonTopic starter
« Reply #15 on: November 21, 2016, 02:54:59 pm »
Tested: Microsoft Surface Book
Offline Luminax
  • Country: my
    • Electronesk
« Reply #16 on: November 22, 2016, 06:17:11 am »
Which is what most 'modern' products these days usually revolves around, "Does it looks chic? can we marketbuzz it to seventh heaven?"
Marketing, kill it with FIER
Jack of all trade - Master of some... I hope...
Offline Red Squirrel
« Reply #17 on: November 22, 2016, 07:09:30 am »
I don't get this obsession with trying to be the "thinnest".  It really does not accomplish much, unless you're trying to stack many of them together.   I'd rather them be thicker and more expandable, have more IO ports, etc.
Offline BradC
« Reply #18 on: November 22, 2016, 08:42:14 am »
Different strokes for different folks. I used to carry a set of scales around when shopping for laptops or accessories. Thin and light is most definitely an advantage when you fly frequently.
Offline AlxDroidDev
  • Country: br
« Reply #19 on: November 22, 2016, 04:19:19 pm »
Gone are the days when IO ports were plentiful on notebooks. I remember my very first laptop had a plethora of IO ports in its sides and back: 2x serial, parallel, 3 audio jacks, VGA, PS/2 keyboard and mouse, 2x PCMCIA slots (who remember those?) and a fax-modem port (RJ11). There was no ethernet port, and I had to use a PCMCIA card to get 10 Mbps ethernet. There was no USB either.
My second one (that's still working, and I still have it), has: 1x PS/2 (for either mouse or kb), 1 parallel, 1 serial, 1 ethernet, 1 VGA, 1 S-Video, 1 modem, 2x PCMCIA, 2 USB, and 3 audio jacks. All of that plus DVD-ROM and a floppy drive.
I've had a few after that, but the one I actually use nowadays has 4x USB3 ports, and 2 of them are combined eSATA3 ports. Only 1 HDMI output and a SD card reader (thankfully not limited to 32Gb). That's it.
Offline G7PSK
  • It is hot until proved not.
« Reply #20 on: November 22, 2016, 04:43:58 pm »
I will stick with my Panasonic toughbook as a portable. Most parts do just plug in so if it fails I just find another. Thin equals weak and bendy.
Offline suicidaleggroll
« Reply #21 on: November 22, 2016, 04:45:57 pm »
To me, thin and light is the whole point of a laptop.  If I wanted a 10 lb 17" monstrosity that was the size of a briefcase, I'd just take a small desktop with me.  Instead, I leave my desktop at home and bring my laptop on the road, which means it needs to be portable, which means minimal I/O.  I love my Lenovo X1 Carbon, not "weak and bendy" at all.
Offline rstofer
« Reply #22 on: November 22, 2016, 07:49:40 pm »
Good review!  I have the high end I7 version and am now using it as my everyday, all day, laptop.  I rarely use just the display separated from the base.  About the only time this works for me is when I am reading a book with Kindle.  I have the separate NVIDIA GPU so I guess I must have bought late enough in the cycle to wind up with the upgraded base unit.  Realistically, my eyes are too old for 2000x3000 on a tiny screen.  When the unit is on a table, I connect it to a 27" monitor and I use a separate Bluetooth keyboard and USB mouse.
We also bought a couple of Surface Pro 4s (wife and grandson) and those also work fine.  There not nearly as powerful but they are probably more portable.  Very nice machines!
I WANT that Surface Studio when it comes out.  The high end unit at near $4100 will probably damp my enthusiasm but I wouldn't be surprised if one shows up on my work table.
Offline NottheDan
« Reply #23 on: November 22, 2016, 10:24:49 pm »
But those were also the days when each external device needed its own specialised port and you were buggered if you didn't have it on your machine. Nowadays it's just a case of temporarily unplugging something else or putting an adapter inbetween.
Offline senso
  • Country: pt
    • My AVR tutorials
« Reply #24 on: November 23, 2016, 04:35:25 pm »
Get a Clevo system. Desktop CPU and watercooling fit in a laptop with 30 minute battery life or no battery at all.
Standard CPU, standard RAM, standard HDD, standard eDP LCD and even dual MXM standard GPU slots. The only custom part is the case and mobo.
Oh, forgot to mention, 5kG of main unit and 1kG of power "brick", really as large as a brick.
What Clevo model as stock watercooling?
Cooling in Clevo chassis is a lucky shot, yes, they have big heatsinks, but QC is almost zero, there are hundreds of reports of crooked heatsinks that make bad contact with the CPU/GPU, you have huge gaps between fans and heatsinks, and the final assembly is done by the store that re-sells them, some of them go the extra mile to assure proper contact and use decent thermal paste and thermal pads, the ones that aim at the lowest price can be a crap shot..
I know someone who as a Clevo that is already on is second board, second heatsink, second pair of fans and the laptop still overheats like crazy...
Currently I have an MSI GT72 2QE with an i7-4720HQ and a 980m, I personally repasted it with just Artic MX-4(will re-do it when I get the time with my beloved Kryonaut), but for now full load temps with both cpu and gpu in stress test is around 75ºC for the CPU, 70-72ºC for the GPU, if I put the fans in full blast they go down to a sweet 50ºC..
And running with Optimus disabled(aka 980m connected to the display and no intel iGPU crap in between) I get 3hr's battery..
If you want/need the brunt of a desktop i7 in a portable package  only Clevo will cover you, if not, you have some options.
