Author Topic: Hazards of Alkaline Batteries?  (Read 1903 times)
Offline Boris_yoTopic starter
  • Country: il
« on: October 20, 2021, 10:50:06 am »
Hello,
When I was cleaning backyard I noticed around 7lbs of alkaline batteries scattered around. Some were burned.
I know alkalines are toxic for environment and should not be disposed as normal garbage. But how dangerous are these to human species? Since I reside on first floor, I wonder if alkalines posed a danger to my health all that time.
Online Siwastaja
Re: Hazards of Alkaline Batteries?
« Reply #1 on: October 20, 2021, 10:56:33 am »
They are pretty benign, not a huge environmental issue either (still, it's not an excuse not to recycle properly).
They consist of Zinc and manganese dioxide. Both used as dietary supplements!
And then the alkaline itself, NaOH or KOH, which is not toxic but as a strong base, is highly corrosive so can cause skin burns, which you would have noticed back then when handling them. Diluted down enough (like 1:1000), you can eat it no problem.
There might be some trace amounts of substances I don't know about but I'm pretty sure environmental regulations have not allowed large amounts of anything really dangerous in decades.
There is no health danger even if you handled leaked batteries or even if you cut one open to examine it. Now if some are burned then this opens doors for all nasty things that are produced when burning anything but I doubt much remains as long as you don't inhale the smoke.
  • Country: il
« Reply #2 on: October 20, 2021, 01:14:27 pm »
Still won't be problem for people with asthma?
Online Siwastaja
« Reply #3 on: October 20, 2021, 03:20:59 pm »
AFAIK there are no compounds irritating to respitory system but of course I'm not a doctor neither a chemist.
Burning anything, including wood and gasoline, releases harmful particulates and gases of course but most are released as smoke.
Really, I wouldn't be worried the slightest about this. Said otherwise, there are gazillion of more probable problems around you, every day, including exhausts from cars.
The following users thanked this post: Boris_yo
Offline ChristofferB
  • Chemistry phd student!
    • My channel:
« Reply #4 on: October 20, 2021, 09:51:01 pm »
I believe all batteries has to state on them if they contain lead, mercury or cadmium. Those are the big nasties in batteries. the manganese is a borderline heavy metal, and not super good, however it exists mainly as manganese dioxide which is insoluble in water and therefore hard to get into the body.
If in doubt, wear gloves.
As for the asthma thing, that's impossible to say. I agree with Siwastaja, I wouldn't worry too much.
--Christoffer //IG:Chromatogiraffery
Check out my scientific instruments diy (GC, HPLC, NMR, etc) Channel: https://www.youtube.com/channel/UCZ8l6SdZuRuoSdze1dIpzAQ
Offline ledtester
« Reply #5 on: October 20, 2021, 11:43:31 pm »
My city - a major metropolitan area in the US - used to collect alkaline batteries but now tells residents to just put them in the trash.
Online David Hess
  • DavidH
« Reply #6 on: October 21, 2021, 11:11:33 pm »
As others have said, the components of alkaline batteries are not particularly hazardous.  The strong potassium or sodium hydroxide (lye, drain cleaner) electrolyte can give a serious burn but diluted with water is innocuous.
Online Siwastaja
« Reply #7 on: October 22, 2021, 09:55:34 am »
Manganese is an important micronutrient and one of the arguments to eat nuts and whole grain.
Yet, at the same time, it's labelled "toxic heavy metal". This group of toxic heavy metals is really interesting, many are important nutrients present in healthy foods and sold as dietary supplements. Lead and mercury are quite exceptional for two reasons, first they have no positive effects so are unnecessary, and secondly quite small amounts can be really dangerous.
For manganese, WebMD says 11mg/day orally, or 55 µg/day by IV, is the safe upper limit. For inhalation, they just warn against long-term inhalation.
So basically, if you eat the batteries, or grind them into a fine powder and breath that in for long periods of time, you may get manganese poisoning. Normally, manganese poses little danger to general public.
On the other hand, eating batteries is really dangerous because of the corrosive KOH, combined with the fact the battery causes corrosive electrolysis within the body.
« Last Edit: October 22, 2021, 09:57:41 am by Siwastaja »
Online Kleinstein
« Reply #8 on: October 22, 2021, 10:52:17 am »
Older alkaline cells included some mercury and maybe lead, but this is a long time ago. They also collected batteries a little longer to also avoid accidential disposal of NiCd cells in the normal wast stream. NiCd cells by now are getting rare, though there are still a few old one around that still work.
  • Country: il
« Reply #9 on: October 25, 2021, 02:35:35 am »
Quote from: Kleinstein
I still have cordless screwdriver / drill set from 2011 that works on NiCAD batteries and use it rarely. I wonder if NiCADs degrade over time in a discharged state and not being used and if they start releasing unhealthy fumes and leak...
Online NiHaoMike
    • Facebook Page
« Reply #10 on: October 25, 2021, 02:49:48 am »
The most common failure mode for NiCd batteries is the self discharge increasing to the point they do not hold a charge for long. In applications where they're constantly being trickle charged, they do tend to last a very long time.
Lithium ion batteries also tend to last "forever" if not abused, although the internal resistance increases over time. The oldest one in my collection is about 20-25 years old and still works great powering a solar charged flashlight.
Offline james_s
« Reply #11 on: October 25, 2021, 02:53:20 am »
They certainly do degrade over time, and it's possible for them to leak but the leaked electrolyte is similar to that used in the alkaline batteries. NiCd cells do contain cadmium which is fairly toxic but it is a metal and won't be leaking out.
Online Siwastaja
« Reply #12 on: October 25, 2021, 04:07:52 pm »
If you see NiCd cells that leak, I would be careful with them. Even though the cadmium shouldn't leak out, it's quite toxic even in small amounts. So just in case, use disposable gloves, put cells in plastic bags, wash hands, get them recycled properly.
But even leaked NiCd cells are't going to pollute the air with cadmium dust.
Online David Hess
  • DavidH
« Reply #13 on: October 26, 2021, 02:10:43 am »
Dendrites form which eventually puncture the separator and short out the cell.  High temperature and low leakage NiCd cells have a thicker separator, reducing capacity, but being tougher they last longer.
I finally gave up on my old set of cordless tools because it was less expensive to buy new lithium battery based cordless tools than to replace the old NiCd batteries, although I could still do that.
