Author Topic: hdmi from cam to pc  (Read 4024 times)
Offline FlumpTopic starter
hdmi from cam to pc
« on: July 24, 2014, 02:12:42 am »
can any of you help me out with this
my eyesight is deteriorating and sometimes i cant see good enough to solder
but on the bench right next to where i solder i have a 24 inch monitor
hooked up to my pc, i also have a old but good digital camera,
so i was wondering if i can link them together to display on the monitor
what the camera see's, knid of a microscope type thing.
here is the camera, it has a small HDMI socket on it
http://www.photographyblog.com/reviews/olympus_sh_50_review/
here is my computer monitor
http://us.aoc.com/monitor_displays/2436vwa
my PC dose not have HDMI ports only USB ones
thanks in advance :)
Offline Richard Crowley
  • KJ7YLK
Re: hdmi from cam to pc
« Reply #1 on: July 24, 2014, 02:16:43 am »
If your camera has HDMI output, then you can connect it directly to the DVI input of your monitor with the appropriate cable and/or adapters.
There seems to be no compelling reason to involve your computer here. In fact, that seems rather like an undesirable complication compared to the straightforward method.
Offline djacobow
  • takin' it apart since the 70's
« Reply #2 on: July 24, 2014, 02:27:41 am »
Are you sure you would prefer the camera+monitor to a good magnifying lamp? The latter has no lag or latency issues.
I don't use mine all the time, but when my eyes are tired, it's a relief.
Offline wraper
  • Country: lv
« Reply #3 on: July 24, 2014, 11:47:44 am »
Optical microscope actually is much better for this purpose. Maih reason for this is that on monitor you can't feel volume. There also is some lag which is very annoying when trying to solder.
  • KJ7YLK
« Reply #4 on: July 24, 2014, 03:59:51 pm »
Which is another reason to NOT route your video through a computer. There is NO LAG if you use a direct connection between the camera and the screen.
The lag is caused by conversion of the native video signal into some compressed format, running it through USB, etc. and back out through the computer.
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #5 on: July 24, 2014, 04:43:23 pm »
Only of the monitor accepts the format and framerate the camera puts out - it's not uncommon that they don't.
A TV on the other hand will almost certainly work
Day Job: Mostly LEDs
« Reply #6 on: July 24, 2014, 11:38:42 pm »
thanks for all your input guys
i didnt realise it was so easy.
the dvi socket on my monitor is in use but i have a vga one too
so i bought this, i hope it works
http://www.ebay.co.uk/itm/231285073041?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
Offline miguelvp
« Reply #7 on: July 25, 2014, 12:00:41 am »
I did a quick scan through the camera manual, what its not clear is if the HDMI output will display anything when it's not doing playback.
Meaning that it might not display a live stream of what the camera sees, only when it's playing back images and maybe videos. But I didn't read the manual in detail, so I don't know what is possible.
Also they warn not to connect the USB cable to a PC if the HDMI cable is in use so make sure you read the manual regarding what can be connected to the camera while using the HDMI cable.
« Reply #8 on: July 25, 2014, 01:39:40 pm »
The adaptor came today and Miguel unfortunately you were right.
When you plug the HDMI in to the camera
only the playback features work
so didnt help at all.
Lesson learned : RTFM !
 :-DD
« Last Edit: July 25, 2014, 02:01:31 pm by Flump »
