Author Topic: Heatshrink plastic bag for small PCB  (Read 690 times)
Offline Martin F
« on: June 28, 2018, 07:26:48 pm »
Hi all,
We're developing a small PCB with a DB9 connector in each end (~5 x 4 cm).
For this we're looking for a simple "wrapping" to protect it - and we thought of heatshrink plastic.
However, we're not familiar with this and wanted to hear if you have suggestions for where/what to look for?
Thanks,
Martin
Online blueskull
  • Country: cn
  • Power Electronics Guy
Re: Heatshrink plastic bag for small PCB
« Reply #1 on: June 28, 2018, 07:31:23 pm »
Maybe 5/8" or 3/4" heat shrink tubes with at least 2:1 shrinkage?
« Reply #2 on: June 28, 2018, 07:36:37 pm »
Yes, though you probably want an adhesive lined heatshrink if you want to have a more robust shrink sleeve. Otherwise you can get by with only a cheap shrink sleeve, as used for bottles, instead of a regular heatshrink sleeve, or even use a shrinkable plastic sleeve like used for wrapping regular goods.  Otherwise look for heat shrinkable tamper proof seals as an alternative, I am using some as shrink sleeves and cable identifier protection, as the ones I got do fit over a BNC plug with ease, and are transparent as well.
Offline edpalmer42
« Reply #3 on: June 28, 2018, 07:54:42 pm »
A quick check on ebay showed heatshrink tubing in sizes up to at least 100 mm in clear or many colors.  Some had adhesive lining, some didn't.
Ed
Offline glarsson
« Reply #4 on: June 28, 2018, 07:58:52 pm »
There is also the choice of normal thickness and the thin version used to hold battery packs together.
Offline Martin F
« Reply #5 on: June 28, 2018, 08:47:02 pm »
Thanks all for the tips ! Any idea what the version for battery packs is called?
Offline glarsson
« Reply #6 on: June 28, 2018, 08:55:27 pm »
Just search for "heat shrink tubing battery pack" on eBay and you will find several examples. The thickness is around 0.1mm.
