Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
General
General Technical Chat
Heatsink to PCB mounting thingies (pins?)
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Heatsink to PCB mounting thingies (pins?) (Read 646 times)
Axk
Regular Contributor
Country:
on:
June 18, 2020, 08:14:20 pm »
For mounting vertical heatsinks like the below (I suppose it has threaded holes for the PCB mounting) what's the name of the thingies that you would mount it to the board with?
Should I just use M3 crews?
Or is there something special-purpose with an M3 thread on one end and that can be inserted into PCB holes and soldered like a component pin?
Last Edit: June 18, 2020, 08:17:37 pm by Axk
Logged
daqq
Super Contributor
Country:
Re: Heatsink to PCB mounting thingies (pins?)
Reply #1 on:
June 18, 2020, 08:24:11 pm »
You can use self tapping screws into the heatsink.
There are solderable threads ( such as these
https://sk.farnell.com/wurth-elektronik/9774015151r/spacer-smt-round-steel-m2-5-1/dp/2497591
Or create a thread inside of the heatsink.
Logged
Axk
rdl
Super Contributor
Country:
Reply #2 on:
June 18, 2020, 08:47:39 pm »
I've seen clip on pins for folded metal heat sinks. The smaller extruded types will often have holes for press fit pins. In both cases the pins get soldered to the board. You may have to go to the manufacturer for the correct part.
Logged
Axk
TimFox
Super Contributor
Country:
Retired, now restoring antique test equipment
Reply #3 on:
June 18, 2020, 09:07:00 pm »
Does "3*3" mean three 3-mm holes, or three M3-tapped holes?
Logged
Benta
Super Contributor
Country:
Reply #4 on:
June 18, 2020, 10:02:36 pm »
M3 or self-tapping? It doesn't matter. On a heatsink that size, you need screws, forget soldering. I'd have expected M4 or even M5, actually.
Logged
Axk
nctnico
Super Contributor
Country:
Reply #5 on:
June 18, 2020, 10:07:27 pm »
Solderable nuts is the term but the heatsink is rather large to be held by solderably nuts. You'll need to mount the heatsink to a chassis or casing.
Logged
Axk
Print
Search
Pages: [
1
Go Up
« previous
next »
General
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
