Author Topic: Beidu - Help to access some FPGA documentation on Beidu.  (Read 688 times)
Online bingo600Topic starter
« on: July 12, 2025, 09:04:19 am »
Just bought a Cyclone IV board on Ali.
https://www.aliexpress.com/item/1005009306876743.html?
I asked seller for documentation , and received this link to Baidu  :-[
Files shared through the network disk: EP4CE6E22 data.rar
Link: https://pan.baidu.com/s/1qL1beGfAS_WuZlxE6R17rw?pwd=v3b3
Extraction code: v3b3
Copy this content and open the Baidu network disk mobile app, the operation is more convenient
I have no access to Baidu , and can't seem to get it working.
I have given up on Baidu  :-\
I asked the seller to provide it in another way: e-mail or wetransfer.
But we seem to have some communications issues , even w. google xlate.
Could some kind person download the file for me, and e-mail or otherwise transfer it to me ?
e-mail will be provided via PM.
/Bingo
Edit: Think someone is working on a schematic here @2025-12-12
https://www.eevblog.com/forum/projects/schematic-for-ep4ce6e22c8n-dev-board/new/#new
« Last Edit: December 10, 2025, 08:09:22 am by bingo600 »
Offline NightMoth
  • Country: cn
Re: Beidu - Help to access some FPGA documentation on Beidu.
« Reply #1 on: July 13, 2025, 01:22:13 am »
Hello, here is file from baidu
The following users thanked this post: bingo600
« Reply #2 on: July 13, 2025, 09:35:34 am »
Thank you so much  :) :) :-+ :-+
Edit:
I'm not experienced in HDL/Quartus
Just spend a few hours scratching my head, as none of the examples worked in 13.0-sp1 linux
Quartus just hung ...
I then deleted all chinese characters in directory names.
Now it works  :-//
Lesson learned ...
No chinese characters in file/directory names, in my setup.
« Last Edit: July 13, 2025, 02:07:55 pm by bingo600 »
« Reply #3 on: July 25, 2025, 06:54:35 am »
I just discovered that the FPGA board has no connection on Jtag (Pin4) Vtgt (Vtarget), supplies the "Target voltage" for the programmer driverchips.
This means programming won't work, until you add a "bodge wire" from "Board Vxx" to Jtag Vtgt pin.
The "Ali pict" (attached) mentions 2.5v as Vtgt.
But i have also seen someone mention, that they used 3.3v ad Vtgt.
I have made a bodge wire to 2.5v, and can program the EPCS4 chip, with the : output.jig file.
« Last Edit: July 25, 2025, 07:51:55 am by bingo600 »
Offline tom66
« Reply #4 on: July 25, 2025, 08:13:21 am »
This is a common issue with JTAG connectors - some programmers generate a default Vtarget of 3V3 if no voltage is supplied, others do nothing.  I think it might come from the old 6 pin JTAG connectors which supply TDO, TDI, TRST, TCK, TMS and GND - no target voltage.
The following users thanked this post: bingo600, croma641
