Author Topic: What's the use of these golden pads on PCB?  (Read 1637 times)
Offline onemilimeter
« on: June 15, 2011, 09:09:25 pm »
Recently I notice "golden pad with distributed holes" (as circled) on several product PCBs. What's the use of these pads? Thanks.
Offline johnmx
  • Country: pt
Re: What's the use of these golden pads on PCB?
« Reply #1 on: June 15, 2011, 10:19:16 pm »
Those are not pads but power traces. Normally they are used to spread the heat and/or conduct high current (very low ohmic trace).
Best regards,
johnmx
Offline hannobisschoff
  • I get high on solder fumes.
« Reply #2 on: June 17, 2011, 11:31:15 am »
So is that actual gold, or some sort of alloy?
Offline Psi
« Reply #3 on: June 17, 2011, 12:25:09 pm »
Probably just standard immersion gold.
Real gold, just very thin. I think it's only like 40 atoms thick but don't quote me.
