I have been playing around with the low power modes of the MSP430 (0.7 uA running my program at 12khz!) and have found that I can power the little fellow off of a 1 inch by 2 inch amorphous solar cell in a room lit by a single 60 watt bulb. There is even a bit of power left over, such that I have the MSP430 monitor the voltage of a separate solar charging capacitor, and when it reaches 4V I activate a 2n2222 to dump it into a led for a brief bright flash. It takes a few minutes for the cap to reach 4V because of the low room light and the fact that the cap is not particularly low leakage type.
Anyway, I would like to make a better solar source for playing around with this, but I want to use a solar cell adapted for all light situations (the amorphous cells work better for indoor scattered light situations, and the mono or polycrystalline cells work better for outdoor sunlight). The new multijunction cells that work super well in all light conditions (30% to 40% efficient) have been announced for a few years, and are probably used in most space applications, but I cannot find a source for one or two of these. I don't really care if they are $100 or even $500 a watt, since I only want a very tiny cell, of maybe 50mW maximum. Any suggestions? I would like to keep everything as small as possible too.
