Hihihi, I read couple of pages with people's shock experience, and I could't help myself from laughing. Truth, some of the stories are dark, but as the topic says, we are still alive, and probably a bit smater from those experiences.
I myself had countless shocks from various sources, I could run a topic thread by myself. Some of them were from carelesness, some from stupidity.
The one that I keep talking about to my friends when this kind of topic pops up, is the shock I received from 20" CRT Mirovideo monitor. 42kg. Sometime around 1996, I think.
The stupid thing was randomly prevailing green color. Like if you would put green film over the screen. Bonk it on a side, it flips back. In time, it required harder and harder slapping, and gone to the point where it was dangerously close to breaking its housing. So, I popped it open. By that time, I was just lightly introduced to electronics, what was dangeorus, what was not.
Don't touch plugged in devices, touch unplugged. If it is plugged, it is safe to tinker near small electronics, it is always at low voltage/current. What bunch of lies...
I called on the phone my in-that-time-electronics-foreman (smartest guy that I knew at that time), explained problem, and he said that one of the circuits (there were three of them, each for one color, I think) behind the tube is going loose, try to find a cracked solder, tinker a bit. Power it on, point to the mirror to see if you make difference.
Easy, I took a small tuning screwdriver, that was all metal, and BOINK
Found live pin on first try. Threw be on my back, and I didn't know what the h*ll happened. Phone rang. It was foreman. "If you are going to tinker on those chips, use toothpick, or a plastic pryer, those mother*****s run on 600V".
Ok, hang-up.
Aaand I started laughing like crazy for a good five minutes.
Sorry for the long post, but since I read some of your stories, I thought I owe you guys mine.
Remember, plastic is your best friend!
