ECMbuster,
This is a great coincidence........
I just bought yet another Roda Rocky as it included the hard disk drive, DVD recorder and power supply. It was the right money
. I already own several Roda Rocky laptops, mainly RT886 models and a couple of RT686 units. From what I can establish, the same hard disk caddy will work in all of the Roda Rocky laptops, which is great news. The caddy is sealed against water ingress so I had not opened the only example I own to date. A have several brand new RT886 units awaiting the day I find the KEL connector so I can make adapters to fit the hard disk in its correct port. Sadly Radio Spares never got stock and have deleted the connector from their catalogue. I am even considering buying a higher pin count KEL connector that they still stock and cutting it to length to give me the correct pin count ! The connectors are not cheap but I have few options.
The latest Roda Rock II purchase came with the hard disk caddy and a hard disk but the caddy was cracked so I disassembled it for a plastic welding repair. This may be the time to create the pin out diagram that you are asking about. I was waiting until I found a source of the connector but now is as good a time as any
The Caddy connector PCB also contains a large SMT diode and that may be a temperature sensor. The caddy surprisingly does not contain a heater for cold environs use. The actual caddy casing is very thin and fragile ABS plastic and a 3D printed replacement is a clear way forward to making a clone. I will take some pictures of the dismantled caddy and begin creating the pin out diagram as soon as I have a spare moment, hopefully tomorrow.
If anyone knows of a source of the correct, or higher pin count KEL connector, as detailed above, I would be interested to hear from them
KEL connectors are found in a lot of rugged laptops but are not that common when trying to buy small quantities. I got lucky with my Getac M230 rugged laptop hard disk connector requirement as a company produced a small batch of complete M230 HDD adapter PCB’s that I bought at £10 each. A bargain
Sadly I can only find complete Roda Rocky hard disk caddy’s at £100 each on eBay. I live in hope of finding cheaper listings. My backup plan will be to buy the 100 contact connectors from Aliexpress and cut them down.
Fraser
