Author Topic: Help identify this electro-optical device?  (Read 1205 times)
Offline VldTopic starter
  • Country: md
« on: September 28, 2023, 02:06:23 pm »
Greetings everyone.
Please help me determine what this is?
Any idea what this is?
  • Country: md
Re: Help identify this electro-optical device?
« Reply #1 on: September 28, 2023, 02:08:30 pm »
2
  • Country: md
« Reply #2 on: September 28, 2023, 02:10:12 pm »
3
Offline Infraviolet
« Reply #3 on: September 29, 2023, 01:00:59 am »
Where did you encounter it, do you know anything about what it may have been connected to or inegrated within? What other context can you provide for it?
The following users thanked this post: Vld
  • Country: md
« Reply #4 on: September 30, 2023, 09:55:37 am »
I bought a variety of equipment many years ago. No additional information available. Please look at additional photos
https://disk.yandex.ru/d/5hFPncUHLOO1jQ
Offline jpanhalt
« Reply #5 on: September 30, 2023, 10:01:57 am »
Unless someone has seen that exact device and knows,  it seems unlikely anyone will have a good guess based on what you show.  Can you take it apart to see what is in the optical path and connects to or though those connectors?
Offline daqq
  • Country: sk
    • My site
« Reply #6 on: September 30, 2023, 07:07:49 pm »
Offline Gyro
« Reply #7 on: September 30, 2023, 07:19:10 pm »
That was my first thought, two terminals and what could be a zero knob (on the end of a taut band suspension).The window looks a bit elaborate with the clamping ring, and small though. If there is mirror visible behind it, it probably is a galvanometer though.
Best Regards, Chris
Offline DavidAlfa
« Reply #8 on: September 30, 2023, 09:45:04 pm »
Maybe a simple ldr, or a photodiode, in a fancy enclosure.
Really hard to guess, make some voltage/ohmic measurements to see how it changes with light.
  • Country: md
« Reply #9 on: October 02, 2023, 12:33:07 pm »
Thanks everyone for the ideas.
I made some measurements (voltage and ohmic) with the tester, but it does not react at all and does not output voltage.
I opened the top cover and took additional photos.
« Last Edit: October 02, 2023, 12:35:50 pm by Vld »
Offline Twoflower
« Reply #10 on: October 02, 2023, 12:44:23 pm »
How about that:
https://www.historische-messtechnik.de/aktive-messgeraete/lichtstrahl-oszillographen/00845.php
Mention the Siemens-Halske Logo at the top might helped a bit. I wasn't sure if that's the logo, because the picture wasn't sharp. But after daqq mentioned galvanometer it narrowed the search down substantially (Keywords I used Siemens Galvanometer Bakelit).
Edit: I have to correct myself. That's a better match: https://www.historische-messtechnik.de/aktive-messgeraete/lichtstrahl-oszillographen/00392.php
Edit2: That's strange the one you have seems to have a SH Logo at the top (so likely from Western Germany) while the one in the link above is from RFT (from GDR). Otherwise the housing looks very similar. It seems that the fixture for this gadget seems similar in east and west.
« Last Edit: October 02, 2023, 12:54:41 pm by Twoflower »
  • Country: md
« Reply #11 on: October 02, 2023, 03:45:48 pm »
Thank you very much for the detailed information. Now it will be easier to sell it.
Sincerely!
Best wishes!
