I'm going to start on the forum with this topic, which is quite interesting!
I'm lucky enough to have access to a local recycling centre with a real intention to give a 2nd life to as much stuff as possible. Grabbing stuff is allowed and even encouraged as a way to reduce the volume of material being sent to waste or recycling. I have grabbed enough fluorescent tubes and fixtures to light a mid-size workshop for probably over 20 years, and 5 big boxes full of old circuit boards from fairly recent electronics.
It's true that most consumer electronics use SMD components which are virtually useless. But since I started salvaging stuff I learned which devices contain the most useful stuff, I even found PICs! No kidding!
I always look for small-sized cooling devices, like wine bottle or water coolers. They often use a thermo-electric module, or even two in a water cooler I dismantled last year. The control boards I got were full of basic component (and were pretty much the same). Each one had a TL494 PWM controller, plus a LM358 amp-op many times.
I seemed to be pretty lucky with battery chargers. One of them had a ST LM339N and a 45uF 450V AC capacitor.
Smoke detectors have some components. The IC seems to be useless though... Carbon monoxide detectors on the other hand! If you find one like this, GRAB IT!
Those I took apart had a PIC in them! The older one are of the PIC16CE series which unfortunately are not reprogrammable, but the last one I got was more recent and inside there was a PIC16F, tada! Even though I probably couldn't read its content, I'm fairly sure I can write my own program.
Last year again, I got a sort of industrial control device which was a goldmine! There was a few UV EPROMs and a 8031, among other things. I would like to put that 8031 in use in a project one day, it's a vintage Intel from the late 1980s LOL.
Compact fluorescent lamps are fun to take apart and repair! I think I have over 30 CFLs successfully repaired.
I always like it when I see a newer washing machine, dryer or cooking range in the scrap metal area! From the last cooking range I dismantled with electronic boards in it, I got a bunch of OMRON 24V relays, a LM324N, a 24C02 and a bunch of other useful parts.
Microwaves also have a great deal of components. Most of them have a microcontroller, but since they're so mass-produced, the microcontroller seems to always be a mask-ROM type. So unless I can find a way to enable a form of external ROM access (kinda like a 8051), they're useless. However those microwaves always use relays to switch the magnetron TX and other parts on. I have a bunch of those relays now, many of them being OMRON! I even dismantled a 1980s microwave for fun and got a board with a VFD display and old, but very interesting discrete components. There's an IC on it, a TL507 ADC. It seems quite simple to understand and could be useful in a future project.
I remember I once found a commercial photocopier from which I got a fairly big Hosiden 240X64 graphic LCD display. Finding a datasheet for it was a pain in the @$$ but I was able to find one from a very similar part with the same pinout, which is an unusual 13-pin. The photocopier's power supply had a bunch of large components.
Upon my last visit this year at the recycling centre I got a Panasonic telephone system, and as I learned, commercial stuff often has more interesting stuff! I found a crapload of PCB-mounted relays, and even neon lamps! Makes sense to find such lamps since they run fine on both DC and AC, and both are used in a telephone network (at different moments though).
There's so much stuff I probably forget, but this may become my official "dumpster diving finds" topic, so chances are I'll add other finds in the future!
