Here in italy a local association is building a open fablab with cnc, lasercut, 3d printer, normal bricolage tools, music, auditorium and a lot of things like this.
I've the responsibility of found the equipment, tools, spare pieces...
So, for the equipment, the various must are:
-good quality
-hight bang per €
-available in europe
-new, not usued
-simple to use, robust.
Probably we need
Power supply (triple, robust... I like the hameg HM7042-5)
Oscilloscope. (rigol 2000 series ones)
Multimeter (portable ones, a few, maiby cheap brymen)
Function gen (simple to use, any suggestion is accepted)
Soldering station (simple, ROBUST, cheap tip... Analog hakko maiby, or pace, ersa, weller... Any suggestion? Must be robust)
Desoldering station (is not necessary, medium quality, suggestion accepted)
Hot air station (medium quality, atten?)
Bench fume extraction (any suggestion accepted)
Lcr meter (with esr, cheap but solid, no cheap china ones)
Pcb etching machine... Suggestion accepted.
Anything else, suggestion assembled.
So... Should we do some brainstorming?
