Author Topic: Help me identify this tactile switch, please  (Read 683 times)
Offline alpherTopic starter
« on: April 08, 2021, 06:32:57 pm »
Here are some pics, bottom line the height of the button is ~25mm or 1", switch is 12x12mm square.
Checked the usual places an all I could find were 12mm max height.
Offline Twoflower
Re: Help me identify this tactile switch, please
« Reply #1 on: April 08, 2021, 06:48:57 pm »
To me it looks like a switch with no more than 2mm button with a custom made extension attached to the switch.
Edit: It seems I was wrong. The extension caps are usually bigger in diameter. And the friendly Chinese has such long tactile switches.
« Last Edit: April 08, 2021, 07:16:51 pm by Twoflower »
« Reply #2 on: April 08, 2021, 08:45:44 pm »
You were right actually.
The switch is just plain unremarkable one with square 3mm button:
Then there is an extension 8x21mm :
I don't really care if it's the same switch all I care are dimmensions 12x12x25mm (the height is crucial ).
Offline tooki
« Reply #3 on: April 09, 2021, 05:32:32 am »
The “extension” is a keycap. You might have better luck searching for that term.
If it’s just a one-off replacement, just keep the keycap and replace the switch. Check drawings carefully as the square shaft dimensions can vary.
Online kripton2035
« Reply #4 on: April 09, 2021, 06:23:11 am »
one of the many use of a 3d printer !
