Hi everyone,
It seems I resolved the issue on my own by fixing my flow switch. Remember that rubber stopper that was hanging on the magnet end? It was helping to hold the magnet in the switch inside of the "float holder". The switch was designed to be mounted VERTICALLY with flow arrow pointed UP. So when flow occurred it would push up on the sliding plastic assembly holding the magnet which was capped by that rubber stopper at the bottom. When that rubber stopper deteriorated the magnet FELL OUT of the plastic assembly so when flow occurred, the plastic assembly would move up but the magnet/rubber stopper wouldn't... So it wouldn't trigger the sensor!
The fix (which I had done previously on my other flow switch years ago) was to simply glue the magnet to the plastic assembly. It turns out that in this particular application that rubber stopper was useless. It wasn't really needed to stop back-flow because there was enough of a vacuum being formed by the pump that it would hold fluid in the tube from drawing backwards through the flow switch anyways.
As far as trying to find a new FCS-X008A part from GenTech..... I will explain BELOW why I went through the trouble of trying to source out the part directly from a parts distributor or a competing compatible part. By the way I got some help figuring out more specs from a company that had a spec sheet:
- 3/8" BSP threading
- < 0.2L/min "on" activation
- Noryl 30%
The only available source for a FCS-X008A was from the manufacturer of the instrument washer. They wanted a ridiculous amount north of $250 for this flow switch, seemingly equivalent to dozens of others which retail for about $15!!!!!!
That is highway robbery! Somehow the only FCS-X008A stock in the world ended up in their hands, and when I explained to them what I thought about them using this flow switch (which is supposed to handle water) for the wrong application exposing it to detergent (turning rubber into dust), or that I wanted specs to determine if I could source a compatible flow switch, or that the cost should be around $15 not $250.... Well they didn't want to hear any of it. Not surprising...
Now that I am out of the immediate urgency and the flow switch works with my "glue hack", I have the time to properly seek this part out without being under duress. I used a composite resin light-cured material to bond the magnet into the plastic housing, the same thing I did to my other instrument washer flow switch 5 years ago and which is still working fine. The detergent did not eat through it yet!
If anything, I hope this thread was a tad entertaining, enlightening and inspirational to anyone who also has some hard to find part that is being charged ridiculous amounts to replace. I'm sure it happens ALL THE TIME in electronics, perhaps not so much in the more common stuff (for which there is often a comparable part) but this electronics-plumbing hybrid stuff (like flow sensors/switches, etc) seem to be an area that may be more specialized. I thought of posting this thread while I ran a cycle through the washer to make sure the pump was working and flow sensing correctly... so far so good...
Time now to screw the thing all back together and pray nothing else breaks on it!
