i have a 7in 5.8GHZ receiver screen "FPV" with a internal 7.4 lithion battery. the battery measures 7.3v... on the battery itself it has a board which doesn't seem to be protection... it looks like the same pcb that they use in lipo battery's. it just what they use to make the series/parallel connection between battery tabs. so this battery measures 7.3v which means in 2cells or 2s. but that board has 3 wires coming off. 1 is + and one is - and the other is marked T on the board. (this battery is internal and screen/device charges it. has a 12v barrel connector)
2 questions:
1. what does the T stand for "Temp sensor?" when i ohm check/volt meter between it and either of the other 2 pads ( + / -) nothing and no voltage
2. how does this battery charge with only 2 wires ( + /- ) im used to lipos which have a balancing lead for each cell.... but it has to be 2 cells since its 7.3v...
