Author Topic: Help with ICs  (Read 397 times)
Offline jackbauerTopic starter
  • Country: jp
Help with ICs
« on: April 28, 2023, 03:38:07 am »
Are the XL74LS08 and 74LS08 the same/equivalent?
Also, is a IC 78L05 voltage regulator a transistor? Because when I search for that IC, I even get pictures of transistors, I need to know exactly how it is.
Offline Kim Christensen
Re: Help with ICs
« Reply #1 on: April 28, 2023, 03:58:16 am »
The XL is probably just the manufacturer code.
The 78L05 can come in the TO-92 package just like transistors do. So yes, it'll look like a transistor, but it's really a 5V regulator if it's labeled as a 78L05.
