Did you cut the chip pan from solid material or was it made up from a sheet? I have heard stainless is a pain to mill.
One place I was in used a vacuum system to hold the fixtures in. They let me try and push it around and man that was an amazing system. Just a minimal amount of vac was all it needed.
I can do the electronics but have only basic knowledge about the machining side. The reason I got one here (a toy really) is just to learn more about the actual machining and programming.
One quick bit on clamping. The biggest clamp I ever got to play with was on a Plasser Butt Welder, it's used to weld rail (railway rail). In normal operation it could pull 80 ton in one go but was also capable of what was called a super pull 120 ton. This is an arc welder that worked by grabbing to rails and tapping them together in a specific sequence. The arc would spin around the edge of the cut track at about 10hz once nice and hot both end would be compressed (80 ton) together (when I say pull this is what I am referring to). Pretty cool, the clamp was about 6 foot long on each track and the machine was the size of 3 1/2 locomotives. The pull ram was massive. The machine needed a new opamp on a sequencer board. I always find that funny, pennies for parts but shipping is a killer, CNR brought the unit and operator out from Ontario to BC for me to repair.
...mike
