Author Topic: Hex confusion: what value is attained when I decrement 0x00?  (Read 4468 times)
Offline iamwhoiamTopic starter
Hi guys. Being used to decimal, naturally, I am confused by this; the part highlighted in red:
LED_PAUSE
                     MOVLW 0xFF
                     MOVWF LED_LOOP2
LED_PAUSE2
                     CLRF LED_LOOP
                     DECFSZ LED_LOOP,F
                     GOTO $-1
                     DECFSZ LED_LOOP2,F
                     GOTO LED_PAUSE2
END
Seeing as "LED_LOOP" has been issued CLRF, and hence contains 0x00, what value does decrementing 0x00 result in; 0xFF?
Hex n00b!
Thanks.
« Last Edit: June 03, 2012, 04:11:06 pm by iamwhoiam »
Offline MikeK
Re: Hex confusion: what value is attained when I decrement 0x00?
« Reply #1 on: June 03, 2012, 04:14:49 pm »
The opposite of what happens when you increment 0xFF.
Offline AntiProtonBoy
  • I think I passed the Voight-Kampff test.
« Reply #2 on: June 03, 2012, 04:42:06 pm »
Google says 0x00 -1 is -0x1...  :-\ or is that just Google fail?
Not necessarily a fail, it depends how the byte is interpreted.
If you interpret 11111111 as an unsigned binary, then its hex equivalent is 0xFF, or 255 decimal.
If you interpret 11111111 as a two's complement signed binary, then hex is -0x01, or -1 decimal.
That being said, hex constant values are generally interpreted as a raw collection of bits with the sign absent, thus I'd find the -0x01 notation unusual.
Offline caroper
    • Take your PIC
« Reply #3 on: June 03, 2012, 08:26:35 pm »
Thanks to binary arithmetic we have finally solved Shakespeare's famous  dilemma.
2B OR NOT 2B = -1
Cheers
Chris
Offline Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #4 on: June 04, 2012, 06:44:42 am »
Quote from: OP
(its been a while). what value will depend on how many bits per byte/register we have and architecture of the "flipflop" (is it the right term?). deducted it to 8bit PIC8 (from your example).. my answer is 0xFF with 1 in carry (or zero) bit. incrementing  0xFF will result in 0x00 with 1 in carry/zero bit.
« Last Edit: June 04, 2012, 06:47:02 am by Mechatrommer »
