Author Topic: hFE gain ranking of transistors & the letter suffix  (Read 901 times)
Offline cvanc
« on: September 26, 2018, 07:36:45 am »
Is there a chart somewhere defining the hFE binning ranges?
Do these ranges stay constant across all transistors (i.e., if an "A" suffix on the p/n represents a beta of, say, 50-100 would it represent the same 50-100 range for any other transistor p/n?
Thanks.
Online Benta
Re: hFE gain ranking of transistors & the letter suffix
« Reply #1 on: September 26, 2018, 08:56:36 am »
No, the letters are relevant only inside one transistor type.
I'll give you an example: the well-known BC547 can be supplied as A, B and C, which divides the hFE range in three.
The high-gain version, which it the BC549 will also come as A, B and C, but the actual hFE values are different.
« Last Edit: September 26, 2018, 09:01:34 am by Benta »
The following users thanked this post: cvanc
Offline cvanc
« Reply #2 on: September 26, 2018, 03:13:03 pm »
Wow, that certainly makes things more complicated.  Seems odd that this never got standardized?
OK, what happens if I buy the same transistors from a different manufacturer?  Would they agree as to the markings & the beta range they signify?  Or are all bets off if I dare to change brands?
Many thanks.
Online T3sl4co1l
    • Seven Transistor Labs
« Reply #3 on: September 26, 2018, 03:35:27 pm »
BC847(A-C) I think is consistent.  2Nxxxx is divided into numbers, often by Vceo grade but there are some hFE graded parts as well.  Japanese numbers (2SCxxx, etc.) are whatever.  Also, there's Korea Electronics (KEC) parts marked similarly, but they are actually KTCxxx and such.
Seven Transistor Labs, LLC
Offline David Hess
  • DavidH
« Reply #4 on: September 26, 2018, 03:37:25 pm »
Different transistor models have a different distribution of hfe.
If the part numbers are the same, then the beta ranges should be the same also although this is not part of the JEDEC registration.
Older parts like the 2N5088/2N5089 tend to use different part numbers for different hfe ranges or colored dot markings like the 2N2926.
Offline rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
« Reply #5 on: September 26, 2018, 03:40:19 pm »
Many thanks.
Always resort to the manufacturer's datasheet.
For example, some of the best transistor datasheets were from Philips (I had a few of their books in the 80's), but over the years they removed most of the curve characteristics on several of their modern revisions. :(
Old Philips:
http://grabstore.ehv.campus.philips.com/voorraadmap/hfdst01_transistors/Datasheets_pdf_files/bc550.pdf
Newer revision:
https://media.digikey.com/pdf/Data%20Sheets/NXP%20PDFs/BC549,550.pdf
