Author Topic: High end solder pencil or low end temp controlled iron  (Read 1240 times)
Offline tron9000Topic starter
  • Still an Electronics Lab Tech
    • My Hack-a-day project page
« on: May 18, 2015, 09:26:06 pm »
Got ask a difficult question a while back: he wanted to solder some wires together at home, but couldn't afford a decent soldering iron with temp control and ask if an antex mains powered soldering iron was ok for the job? I have used antex ones before, they're not that bad I find.
Got me thinking, if you were starting again out on a budget? which would you go for?
Also, which side of the sponge do you use? orange side or yellow soft side - or is it a case of there is only one side you should use?
Partsbox.io - orangise your parts!
"If you're green you can only ripen. If you're ripe you can only rot!"
