The voltage a transformer will tolerate varies approximately with the frequency supplied to it. A transformer from a 220VAC SMPS would likely have +/- 300V applied to the primary, and if it was designed for 300kHz then it might only tolerate (60Hz/300,000Hz) x 300V = 0.06V. Not much all. Probably an oversimplification, but you get the general idea.
