Author Topic: High intensity white LED  (Read 1667 times)
Offline Mike WarrenTopic starter
    • Personal Website
« on: February 07, 2014, 05:58:59 am »
Does anyone know of a place in Australia that might be able to supply LEDs like the one shown in single quantities?
This is all I know about it.
- Looks to be about 5000K temperature.
- Body size is about 6mm x 7mm.
- Voltage drop is about 3V
- Current around 180mA
The main problem I have is the case style.
Offline djococaud
  • General rule : Simpler is Better
    • Djo Labs
Re: High intensity white LED
« Reply #1 on: February 07, 2014, 07:07:32 am »
Looks like OSRAM Dragon LED,
http://au.element14.com/osram/lww5smjykyjkql-4/led-hi-bright-golden-dragon/dp/1860538
Not cheap, but you can order from one piece...(you'll want to look for the shipping costs, becauce it comes frome UK)
Have a nice day !
PS: you can solder it by hand but make sure you add some thermal grease underneath... (and good luck to desolder the bad one, with the thermal pad soldered on PCB !)
« Last Edit: February 07, 2014, 07:11:11 am by djococaud »
    • Personal Website
« Reply #2 on: February 07, 2014, 12:22:23 pm »
Thanks. That looks like it might do the trick.
I've already unsoldered the old one with a hot air rework station.
