Top to bottom:
Blue ratcheted insulated crimper
Engineer PA-21 / Engineer PA-09 / Yellow Coax/Cat5 stripper
Blue ratcheted RJ12/45 crimper / Engineer PA-01 / Yellow $1 Cat5/6 stripper & punchdown tool
Altima/Excelta cutters (get a decent set of these if you buy any good tools) / One of the above automatic strippers
6point Wire Ferrule Crimper / Automatic Stripper small gauges / Automatic stripper medium gauges
The Engineer PA-01 (white) is super handy as it does insulated and non-insulated crimps, crimps with the two-part wire and sheath foldover wings, bolt cutting, wire stripping etc.
Apart from the excelta cutters and engineer stuff, its all made in china spec. Blue ratcheting crimpers were <$15 delivered. Coax stripper was a few $, the punchdown/stripper for ethernet cabling are a buck a piece. I think I pretty much have all my stripping and crimping needs covered. There's a big hydraulic hex crimper somewhere that does up to 70mm^2 cable. It's very handy to have the tools to do everything even if you don't think you'll use it much. If you do find yourself using one heaps, then you can feel confident spending $50-100 on a good brand one knowing it'll be worthwhile. I just can't justify $100 on an RJ45 crimper when I'll only use it occasionally (and this one actually works really well).
