Author Topic: High voltage power supplies  (Read 3674 times)
Offline djsbTopic starter
« on: June 04, 2010, 02:22:18 pm »
Just been watching the latest multimeter shootout video and noticed Dave using a Keithley high voltage power supply and current supply for testing the meters. What is the power supply model that's used and can anyone generally recommend a high voltage power supply? It would mainly be used to experiment with valve amplifiers and general lab use. Thanks.
David.
Hertfordshire, UK
University Electronics Technician, London, PIC16/18, CCS PCM C, Arduino UNO, NANO,ESP32, KiCad V8+, Altium Designer 21.4.1, Alibre Design Expert 28 & FreeCAD beginner. LPKF S103,S62 PCB router Operator, Electronics instructor. Credited KiCad French to English translator
Offline rossmoffett
Re: High voltage power supplies
« Reply #1 on: June 04, 2010, 04:05:42 pm »
I use a Variac and whatever high-voltage transformers I have around.  HV power supplies are expensive!
My line voltage is on the high end (~125 VAC) so I get almost 7 VAC on my filament taps.  Tubes will operate on as low as 5 VAC with no harmful effects, so that gives quite a bit of adjustment on the HV windings with a variac.  About +/- 50 Volts, depending on the voltage range you're working in.
ArcAttack - A group of musical Tesla coil performers with semi-regular blog updates.
Offline Simon
  • Global Moderator
    • Simon's Electronics
« Reply #2 on: June 04, 2010, 09:21:23 pm »
well you could use a voltage doubler rectifying solution and maybe two of those in series if you want 1000 V if your just after low power, infact you could get as much as 1200 V, or maybe best using a proper multiplying rectifier circuit, but this only works on low power
Offline Kiriakos-GR
  • Country: gr
  • User is banned.
    • Honda AX-1 rebuild
« Reply #3 on: June 05, 2010, 12:11:16 am »
My own question would be , how to measure  2000V  with one 1000V DMM ?   ;)
Online NiHaoMike
    • Facebook Page
« Reply #4 on: June 05, 2010, 03:36:16 am »
Build a voltage divider.
http://repairfaq.org/sam/hvprobe.htm
Offline EEVblog
« Reply #5 on: June 05, 2010, 05:12:13 am »
I have 4 Keithley instruments:
240A high voltage PSU
225 Current Source
260 Nanovolt Source
261 Picoamp current source
Dave.
alm
  • Guest
« Reply #6 on: June 05, 2010, 01:04:56 pm »
Unless you are experienced in high-voltage construction, buying a HV probe would be the safer option. It's not like DMM HV probes are that expensive.
