I LOVE the look of old components like Capacitors, when rebuilding old Tube Radios etc...
We've all seen/done rejuvenations where the chassis underside is now full of bright blue Electrolytics,
and various 'new' other types, that take away the authentic '
old/original' look, historically.
It's clever, when people pull out the guts though, of an old '
Can' on the
chassis top, and re-stuff it
with new capacitors, or even slice open the outer wrapping of old
Paper/Wax caps, and hide the new
replacement ones
inside, and re-seal them! I just worry though!....
ONE day in the future, someone is going to see them, and say... "Oh... I better cut all this old crap out!"
I hope people at least leave a
NOTE inside, informing them of what's been done! haha...
The WORST that some people do, (in Mains powered units), is replace the Rectifier Tube with a couple
of modern Diodes under the tube-socket. Argh... (The tube is generally a Duo-Diode, and works from a
centre-tapped transformer, to attain Full-Wave rectification). Apart from the 'Looks', they do NOT behave
the same!! Amongst other things/reasons, the 'Cathode' in these are usually '
Indirectly Heated", so that
it takes longer fully come up to working levels, as opposed to the other tubes present, to reduce inrush
current, and over-voltage in parts, on start up. To me, they are all about the 'Looks' though!!
