Personally, I think computerized mathematic tools aren't a bad thing so long as your class doesn't let you get lazy with it.
In my Algebra and Trig class, (which required a TI-83/84 series, but I used an HP-48G moving onto an HP-50G because screw TI and go HP) calculators of course were useful for number tables and basic plots, but as long as it wasn't a CASulator, all I could do was bang out of a few numbers really fast, which definitely helped speed up the learning process. Once Calc 1/2 hit, I upgraded to an HP Prime, and yes, while the 50G is a CASulator, it wasn't something I used in any extent until pre-calc which was just a really shitty online class.
That HP Prime, let me tell you, because of the rules of the class allowing you to use cheat sheets on the test full of whatever examples or generics you want, I could fill that baby up with as many notes as I needed. The CAS functionality REALLY helped me get through the often very thick Algebra that I knew how to do anyways, to quickly check the answers of my problems. Of course there was the possibility of human error, but the HP Prime didn't give you any steps. You either had to give it some, or have everything go in one fell swoop, which only goes so far.
While the other students had TI calculators which cost about as much as my fancy HP Prime (was bought for around 110 USD), I could bang out the answers to entire maths problems in moments. Now, you have to understand in a modern maths class, the answer is 120% worthless. If you only give the answer to a problem, you will be lucky to get 50% on the test. As stated, the HP Prime just lets you check yourself, make sure that you didn't make a stupid mistake on paper. I still had to compute, evaluate, and even graph by hand, using the same tricks and techniques I would use otherwise. It was a GREAT learning tool and assistant, something that I wouldn't have done as well in the class without, not because it helped me cheat, but because it helped me learn.
Today, the HP Prime is the best calculating tool. It even gives PC CAS engines a run for it's money with Xcas being a PC implementation of the same CAS library. However, without RPN, which is the second best feature by a close margin of the HP Prime, seriously RPN is awesome, I always keep an HP Prime emulator on my desktop to use for quick maths.
