Author Topic: Honeywell Galaxy Flex alarm panel - factory reset.  (Read 6773 times)
Offline GostekTopic starter
« on: March 16, 2017, 07:50:13 pm »
Hi all,
I recently got two Galaxy Flex alarm panels from eBay (+MK8 keypads) and was going to install (only one) at home. However it seems to be much more complicated than my other
Honeywell Optima in the garage :). I think I can manage, but unfortunately both panels are used and already programmed. I got no engineer codes.
Do you have any idea how to reset them to the default settings? Or know someone who can help on that?
Best Regards,
Gostek
Offline Gregg
Re: Honeywell Galaxy Flex alarm panel - factory reset.
« Reply #1 on: March 19, 2017, 03:36:33 am »
try posting your questions on this forum:
http://www.shieldlab.com/forum/index.php
There are a number of qualified alarm installers that follow this forum; they don't get into things like modifications or hacks and are mostly true believers in the god of "UL Listed" but that doesn't mean they can't be very helpful.   It is good forum for commercially available alarm systems with almost no BS or trolling; two thumbs up.
« Reply #2 on: May 02, 2017, 08:45:06 am »
Thank you for suggestion,I will try it.
Offline jc101
« Reply #3 on: May 02, 2017, 03:50:03 pm »
Have you tried the default engineer code of 112233 and a user code of 1234 to enable it via the menus?  I don't think it's much different to the old Galaxy panels.
I have a note somewhere here over how to reset a Galaxy panel...
