Pneuvay Engineering comment on Centrigual vs Regenerative blowers.....
http://www.pneuvay.com.au/pneumatic-conveying/news/Centrifugal-blowers-vs-regenerative-blowers---The-BIG-difference/CENTRIFUGAL BLOWERS VS REGENERATIVE BLOWERS - THE BIG DIFFERENCE
Centrifugal and regenerative blowers are widely used in industrial processes. Both can look very similar but there are many distinct differences you should know about these two blowers such as the following:
CONFIGURATION OF CENTRIFUGAL BLOWERS AND REGENERATIVE BLOWERS
Distinct differences are clearly seen in the configuration of these two blowers as explained below:
Centrifugal blowers are configured such as its inlet and outlet are perpendicular. The inlet feeds air into the centre of the impeller while the outlet stays in tangential to the rotation of the impeller as shown in the image below.
centrifugal blowers vs regenerative blowers
On the other hand, regenerative blowers have parallel inlets and outlets that are positioned perpendicular to the rotation of the impeller as illustrated above.
IMPELLERS AND IMPELLER CASING OF CENTRIFUGAL
Centrifugal blowers allow air to enter at the centre of its rotating impeller where a number of fixed vanes acts as paddles that pushes volumes of air to the outlet. Through a centrifugal action, air is forced to the impeller and housing where it is discharged as steady steam through the outlet. This creates negative pressure at the centre hub that sucks in more air.
Centrifugal blower working principle
Unlike centrifugal blowers, regenerative blowers are fashioned in a different manner. It consists of an impeller that spins within a housing compartment, which contains both an inboard channel and an outboard channel; thus an alternate name given to it as side channel blowers. The moment the impeller spins past the intake import, air is drawn in and is trapped between its impeller blades. As it continues to spin, air is pushed both inward and outward through both of the channels. This continues until the impeller stops rotating. As a result, regenerative blowers can act either as a pressure blower or a vacuum blower.
Regenerative blower operating principle
MAINTENANCE OF CENTRIFUGAL BLOWERS
In comparison, centrifugal blowers require more frequent maintenance compared to regenerative blowers because of certain parts that requires lubrication, particularly its bearings. Regenerative blowers are considered contact free machines thus it is virtually maintenance free and can operate up to 40,000 hours without the need of being serviced.
NOISE LEVELS OF CENTRIFUGAL AND
Regenerative blowers showcase extremely low noise which make it a favourite for noise-sensitive applications. Talk to us to know more about our centrifugal blowers with low noise level for your specific requirement.
APPLICATION TO INDUSTRIES OF CENTRIFUGAL
As a general rule centrifugal blowers are considered low pressure, high flow blowers while regenerative blowers are high pressure, low flow blowers. This makes it ideal for the following industry applications:
APPLICATIONS OF CENTRIFUGAL BLOWERS
Centrifugal blowers work for applications such as heating a furnace with hot air where a large air volume is required to fill the space. This includes:
Climate control
Cooling machinery
Dryers
Dust collectors
Exhausting gases and vapours
Filter installations
Food industries
Furnaces
Grain elevators
Printing machines
Hot air blowers
Household machines
Incinerators
Machinery for the food and beverage industries
Plastic extruders, laminators, film processing machines
Pneumatic transport
Pollution control equipment
Uniform temperature equipment
Textile machines
Woodworking machines
APPLICATIONS OF REGENERATIVE BLOWERS
Regenerative blowers are mostly used in flammable gas, hazardous duty, industrial air movement, water treatment, and heavy duty transportation applications such as:
Aquaculture/pond aeration
Chip removal for engraving equipment
Dust and smoke removal
Industrial vacuum systems
Packaging applications
Pneumatic conveying
Printing presses
Spas and dryers
Sewage aeration
Soil vapour extraction
Vacuum lifting
Vacuum packaging
Vacuum sintering and casting
Pneuvay Engineering distributes Spencer centrifugal blowers and regenerative blowers. Talk to us at 1300721458 to know how we can deliver these to your business.
