That's good, as long as somebody's going to earth it.
I didn't mean to worry you but that really is a pretty serious one. Even if it wasn't an official visit, I would have expected that he would have taken a few minutes to make it safe - depending on whether it's a TN-S (earth bonded to outer supply cable sheath), TN-C-S (earth connected to incoming neutral) or TT (separate earth rod - ok that one would be an undertaking). It would have had an earth at one time.
What annoys me, is we did have another electrician before all this come to take a look at the socket that blew under the sink. Instead of condemning it as I believe he should have, the cowboy put a new one in place. What happened? It blew again. He's not be invited back.
EDIT - I forgot to add regarding the sign off. When we bought the house in the buyers pack was the certificate for the electrics that had recently been "Tested" by the owner. I'm still sure it was his "mate".
That's why I have an innate distrust of tradesmen, garage mechanics etc. They don't have any direct stake in the quality of their work (I'll hold back on the bodged rear brake and loose wheel episode!).
If your solicitor accepted an inadequate certification in the homebuyers' pack then you may have some comeback against them. It might be worth getting a free one hour introductory consultation with another solicitor to see if they were negligent. I've done it (with an employment matter) and got an out of court, no blame, settlement from the first solicitor. Best case, it might pay for a rewire. Just a thought.
Not sure how the solicitor would check? Because the certificate is a legit certificate but I just have a feeling it was a "mate" the house owner knew in the trade who signed it off.
I'm thinking the earth issue isn't probably as bad as I've describe. We 100% trust our friend and know he wouldn't have left it unsafe. They just said something about needing to run a cable from the consumer unit, to the pipes under the stairs to create the earth. Unfortunately that means lifting floor boards to get it to the point it needs to go, so I assume wouldn't be a 5min job. We'll see when he comes round to do the earth, I'll be helping (holding a torch).
Ah, ok. It sounds like the earth bonding of the incoming services is missing - you're supposed to have equipotential earth bonds to the incoming services (gas and water - if it's not a plastic pipe) in addition to the mains earth cable bond (assuming that you
don't have a TT system with an earth stake). It still ought to pass a socket test though
I've taken to picking up the odd bit of second hand professional electrical test gear so I can do my own testing as often as I want. In addition to a decent voltage tester I've got an earth loop impedance/prospective fault current tester and a proper RCD tester which measures trip time to confirm that they still meet standards. Both are simple to use and plug into a mains socket via an IEC lead, so no exposed wiring hazards.
The ELI/PFC tester is a Socket & See (Yes I know, silly name but they're UK and part of Kewtech) PDL310 (complete with British gas logo). It has all the functions a standard socket tester has in addition to the measurements - There's a later PDL230 which has LEDs to indicate value ranges rather than actual figures. The RCD tester is a Robin 5406. I picked both up for relative peanuts on ebay, much better than the basic stuff from Toolstation and Screwfix.
Even though this stuff is out of official cal period, it's well able to handle the duties of going round the sockets every now and again (obviously not the RCD test, that only needs to be done once per circuit) to check their integrity, spot high contact or wiring resistances etc. in time for proper remedial action. From the measurement I've done, they're still in cal anyway. A little reading of the free IET 17th / 18th edition installation related documents on the web is enough to confidently understand these sort of checks.
As others have said, a fused spur off a ring circuit is fine for an alarm supply - the only time that you'd want it on a separate circuit is if you're worried about it going off if the ring circuit trips. Modern consumer units have so many ways though that everything seems to end up on its own breaker.
