Today something happened to me I always deemed quite unlikely. While hanging a lamp, I made sure to take every precaution I could think of, partly because someone inexperienced was helping me and I wanted to show what you can do to work safely and protect yourself. After mounting the hook to hang the new lamp from and making sure the wall lamp switch was in the off position, I turned everything off at the breaker panel again, put on some rubber gloves and peeled the tape from the wires to connect everything up. It was at that point that someone poked his head around the door and told us it was odd how the lights were still not on, as he just turned things on at the breaker panel again.
It turns out he had arrived, concluded the lights weren't working and started messing with the breaker panel close to the doorway right away. It seems he didn't quite understand how the breakers work, as he just flipped the big switch and you need to flip the smaller switch too to get things powered up again. Of course, making sure the light switch in the room I was working was actually turned off and wearing gloves should have saved my bacon regardless, but I can't believe how unbelievable unlucky that timing was.
I never figured it to be very plausible for someone to turn up and to mess with the breaker panel at those exact 60 seconds I was touching the actual wiring, yet that's exactly what happened. Obviously, my mistake was not to put up a note at the breaker panel. It might be missed in the dark, but it's a lot better than nothing. I blame myself for that, as I had consciously told myself to do that yesterday. Unfortunately the panel can't be locked, so that was not an option. I hate to think I might have been more careless if I would have been on my own. Even if the power had been turned on properly, there was still more needed for things to go awry, but I consider it a close call regardless. Another unseen problem like the light switch being wired backwards or not being properly double throw could have easily defeated another precaution. I actually felt stupid for putting on gloves, but it turned out to be more sensible than I ever expected. I thought I'd just share the experience as an example of how quickly things can devolve, to learn from my mistake and that taking every precaution isn't a stupid thing to do at all, even if you do feel you're being overly careful.
Have you had any close calls?
