How about these, just a quick search away.
Basically you dip the resistor body in a pool of paint to get the full body coat, dry it with heat, and then to get the bands on you use washers running on the top of a bath of pigment to transfer the bands across to the resistor, dry again with heat and then tin the lead ends to finish the product.
