I have seen a CB trip with an incandescent globe filament failing, twice over the last 40 years. The cause may be simple... as the filament fails and dislodges, shorter remnants of it shorts out the active and neutral wires elsewhere, causing excessive current and blowing the CB.
Incandescent light bulbs are illegal in Australia and soon halogen light bulbs will be banned...
https://en.wikipedia.org/wiki/Phase-out_of_incandescent_light_bulbs. From September 2020, those with the Vision Mantis here might have a problem getting their globes. Fortunately, Australian government policing of imports is very weak.... just buy them on eBay. However, I finally found a good LED alternative for the Mantis - less heat, less power, and you can disconnect that noisy fan.
