Author Topic: Potentiometer with switch  (Read 2795 times)
Offline king.osloTopic starter
  • Country: no
« on: November 04, 2011, 11:11:06 am »
Hello there,
I have bought some Bourns multi-turn pots and some knobs. I have noticed that on some devices, when you press what could be a potentiometer, you switch some kind of functionality.
What kind of push button is normally used for this, and where is it placed in the assembly?
Thank you for your time.
Kind regards,
Marius
« Last Edit: November 04, 2011, 11:19:51 am by king.oslo »
Offline sub
Re: Potentiometer with switch
« Reply #1 on: November 04, 2011, 11:20:04 am »
I've not seen one on a pot, but rotary encoders often have them built in.  Mounting one separately would probably be overly fiddly.
Offline Simon
  • Global Moderator
    • Simon's Electronics
« Reply #2 on: November 04, 2011, 11:22:59 am »
I think the switch is usually on the back of the pot, sometimes in it's own housing
Offline FreeThinker
  • Truth through Thought
« Reply #3 on: November 04, 2011, 11:31:19 am »
Have a look at these http://www.omeg.com/products.htm#switches
Quite a common item ;)
Machines were mice and Men were lions once upon a time, but now that it's the opposite it's twice upon a time.
MOONDOG
Offline hacklordsniper
  • Country: hr
  • Don't turn it on, take it apart!
    • HackLordSniper
« Reply #4 on: November 04, 2011, 12:10:40 pm »
Alot of devices today have such instaled (example radios) to turn the appliance on with volume pot as example
Oh, the joy of sending various electronics to silicon heaven
  • Country: no
« Reply #5 on: November 04, 2011, 02:40:00 pm »
Yes, is it possible to buy a switch like this for the pots I already have?
Thanks.M
Offline david77
« Reply #6 on: November 04, 2011, 04:44:47 pm »
Pots with a "turn-to-switch-on" switch are standard items and have been for many decades, see the link above or have a look at Piher pots.
So far I have not seen off the shelve pots with the "push-pull" variety of switches like they are often used in scopes.
Also I don't think there is an easy way to get a switch function added to a standard pot, you would have to make up something mechanical to add this feature - seems to be too complicated to be worth doing, IMHO.
Offline IanB
« Reply #7 on: November 04, 2011, 05:15:05 pm »
I don't think so. You buy the part as a complete assembly, like this for example:
http://www.bourns.com/pdfs/PDB183.pdf
