Is there a more simple test like measuring the mains having a diode in series with one of the probes to break the sine wave ? Would that have different reading between an rms vs. non-rms meter ? what should that reading be ?
Thanks T4P... That information about it's chipset gave me a lot more confidence about it.
My other meter is a Mastech MS8229. Not fast refresh rate, fast but not latched continuity test, no analog bar, no rms.
The cheap rms meter that I -would- love to buy is the BK 2709B
But I live in Argentina and the only way for me to buy a DMM that matches my budget is through sites like dealextreme, dinodirect, tinydeals, aliexpress, etc. And you have to pick out of whatever happens to be available there.
I'm thinking in trying to mod/hack my MS8229 to add latching to it's high responsive continuity tester.
Why don't they use an ac-coupling cap inside the meter?
Anyway back to how to test True RMS on a meter. Feed it any logic level square wave of a low frequency, say 100Hz, and the meter should read 1/2 the logic level. It is that easy.
Is that right? If you have a positive going square wave with a 50% duty cycle the voltage will be on for half the time, which means it will deliver half the power of a continuous voltage. That means the true RMS voltage should equal the logic level divided by the square root of two.
I'm about to buy a ridiculously cheap DMM with true RMS (Uni-T UT61D)Be aware that although the 61E measures true RMS, it is defeated if any DC offset is introduced, like most TRMS meters are.
It is so cheap that I'm skeptical and want to test if it is really measuring in true rms.
How can a create the most simple test without a function generator ?
Maybe creating an AC square wave with a 9+9 transformer and checking if the rms meter in ac mode matches the peak voltage and verifying that my other meter has a lower value ?
Please don't tell me that it's stupid to buy a measuring device that you don't trust... I know that.
I'm on a tight budget.
You're not measuring it right.
Wytnucls: I had to do some reading and some googling to fully understand your explanation but now I have a much better understanding of all this.Well, as TP4 was saying earlier, the easiest way would be to feed the meter any waveform that is not a sine wave, since the non-TRMS meter is calibrated to give you a voltage based on the sine wave TRMS formula.
Thanks for taking the time to reply.
This means that it's not a good idea to use a 0->5v square logical signal to test it.
And it's also not a good idea to use half of the waves of the main using a diode to break the sine wave.
I have to really have a non-sine AC signal with a balanced positive and negative stage.....
.... so... what could be the easiest way to create it -without a func gen- ?
...what about having the 5v AC sine wave of a transformer passing though 4 diodes connected in parallel with another 4 in the opposite way like this:Code: [Select]---+---|>|----|>|----|>|----|>|----+----
thus erasing big/long parts of the wave in which the voltage is low maintaining the balance of the parts untouched.
is that a good idea to create a clean non-sine AC wave with no DC offset ?
True RMS should not care about DC as long as the peak is within the dynamic range of the converter input. It should give the correct result if you put in pure DC, or with an input of half Dc and AC on top of it. I have some TRMS converter chips around, old AD devices. Need +-15V rails, but do not care as long as the input is in range, crest factor of up to 13 AFAIKR on a 2V pp signal.
True RMS should not care about DC as long as the peak is within the dynamic range of the converter input. It should give the correct result if you put in pure DC, or with an input of half Dc and AC on top of it. I have some TRMS converter chips around, old AD devices. Need +-15V rails, but do not care as long as the input is in range, crest factor of up to 13 AFAIKR on a 2V pp signal.You are wrong.
"Let's reserve true RMS for those meters that measure the signal many times per second, square it, sum the measurements over an interval, and display the square root of the mean." IanBThe meters I'm talking about do that, the inputs are just AC coupled, as you would expect in VAC mode. I would be very annoyed if they would respond to DC voltages in VAC mode, this would make them useless for tasks like measuring power supply ripple.
I agree with Ian, as this is what the AC+DC meter does, giving you an instant true RMS value on the screen and coping with a small variation in DC offset easily.An AC+DC mode is convenient, I agree that it is annoying to get out your calculator and measure two values, especially for fluctuating signals. AC coupled RMS measurements are not wrong or misleading, however, as you seem to imply. If you're asking for VAC, then it should not take DC voltage into account.
A change in duty cycle is not a change of DC offset, by the way. The voltage hasn't changed at all.An AC signal has a mean of zero. What happens to the mean voltage as you change the duty cycle?
That is also assuming that the meter AC readings are correct in the presence of a DC offset, which there are not in the case of the 61E, introducing an extra 1% error. This could be insignificant for most applications, but an error nonetheless.This sounds like a flaw.
Here is a Fluke write-up on the subject:
http://www.fluke.com/fluke/usen/community/fluke-news-plus/ArticleCategories/DMMs/True-rms+Facts.htm (http://www.fluke.com/fluke/usen/community/fluke-news-plus/ArticleCategories/DMMs/True-rms+Facts.htm)
If the meter doesn't measure true RMS correctly, including any DC offset, then it is not a true RMS meter. There is no point calling something what it isn't.
