Author Topic: Need some help identifying a part  (Read 566 times)
Offline cdnsoundguyTopic starter
« on: February 01, 2022, 10:34:34 pm »
Greetings,
Long time lurker, first time poster.
My father was an EE and after he passed a few years ago his collection of spare parts and components fell to me.
I have finally found sometime to go through his collection and I came across a ziplock bag of 500 green components all marked with "LF 1/4A".
Please see picture. The bag was marked "TECHTROL".
Does anyone know what the part is? It has a resistance of 0.34 ohms.
Thanks.
cdnsoundguy
Offline bob91343
Re: Need some help identifying a part
« Reply #1 on: February 01, 2022, 11:33:23 pm »
Fuse.
The following users thanked this post: cdnsoundguy
Online Fraser
« Reply #2 on: February 01, 2022, 11:38:59 pm »
It is a 0.25 Ampere (250mA) PCB mounted fuse made by Littelfuse (LF)
The pictured fuse appears to be from their “PICO” range ……
https://m.littelfuse.com/products/fuses/axial-radial-thru-hole-fuses/pico-fuses.aspx
Example datasheet:
https://m.littelfuse.com/media?resourcetype=datasheets&itemid=7ef7dafd-7227-456e-888b-ea80c7afdc1d&filename=littelfuse-fuse-251-253-datasheet
« Last Edit: February 01, 2022, 11:46:45 pm by Fraser »
Offline Alex Eisenhut
  • Place text here.
« Reply #3 on: February 02, 2022, 03:43:10 pm »
Yeah, fuse. A typical use for them back then was on PC motherboards for the keyboard power line.
