Author Topic: How dangerous is a Mode 1 EV charger?  (Read 1138 times)
Offline FaringdonTopic starter
« on: August 14, 2021, 10:01:19 pm »
How much more dangerous is an Electric car with a mode 1 charge point, when compared to this type of electric shower?...This type of electric shower is used by many tens of millions of people every day, without problem....
'Perfection' is the enemy of 'perfectly satisfactory'
Offline ataradov
    • Personal site
Re: How dangerous is a Mode 1 EV charger?
« Reply #1 on: August 14, 2021, 10:20:33 pm »
Why would they be dangerous? Are you into some new conspiracy theory?
Alex
The following users thanked this post: Faringdon
Offline Benta
« Reply #2 on: August 14, 2021, 11:18:40 pm »
Ignore it. "treez" is bored.
The following users thanked this post: tooki, bd139, Faringdon
Offline Ian.M
« Reply #3 on: August 15, 2021, 01:16:43 am »
Do bearz sh!t in the woodz?
Online Siwastaja
« Reply #4 on: August 15, 2021, 08:06:52 am »
The danger relates to the long lasting tradition of manufacturing and selling substandard wall sockets while the authorities look in other direction. For example most of the Europe uses the Schuko sockets and plugs which are rated at 16A (and testing procedure includes 22A load test for half a hour if I recall correctly) but in practice if you load these plugs at 16A for hours in wide scale, electric fires will be common. Nothing technically ever prevented making Schuko sockets and plugs that can take 16A*1.5 (to blow an upstream 16A gG fuse) for an hour or two even when aged, but that would've been more expensive. It's race to the bottom, we do this in Europe as well, always did, the brag about safety of our local products is mostly empty talk.
Such fires happened before EV charging but no one gave a shit. Regulators let this happen. But now suddenly having a lot of EVs everywhere made the problem worse, so the solution was to limit charging current significantly, e.g. for Schuko plugs different legislations ended up between 6A to 10A. Limit current to such low value and fire safety will be fine, obviously you can always find a seriously damaged old outlier socket but if this burns your house at 8A then this would happen sooner or later anyway with any type of load.
AFAIK the British plugs and sockets are significantly better.
« Last Edit: August 15, 2021, 08:10:26 am by Siwastaja »
Offline Gregg
« Reply #5 on: August 15, 2021, 05:05:13 pm »
If a treez fell in the woodz and no one replied, would it matter?   ::)
And could a fallen treez return to upright without group assistance?   :palm:
Would the bearz care?  :-//
